WTO hydro... pulling to one side?
Discussion in 'The Garage' started by jekbrown, Feb 18, 2003.
  1. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    I finally got a chance to drive my rig more than 2 blocks today... and I noticed that my steering tends to pull towards the passanger side. I thought maybe the ps system wasnt bled enuff, so I jacked the axle up, started her up, and went lock to lock a bunch of times. While i was doing that I noticed that if i let go of the steering wheel it would, on its own, slowly turn towards the passanger side.
    any idea what the deal here might be? is it just 'cause i have hydro or....? any help appreciated, as always,
    j
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Did you call WTO yet? Seems like that would be a good place to start! /forums/images/graemlins/thumb.gif </font color>
  3. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Yep, I agree with Shaggy. Better call WTO. I installed a complete setup with no problems. Sounds like the spool valving in your box may be off.
  4. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    if you'd install hy-steer it wouldn't do that /forums/images/graemlins/laugh.gif /forums/images/graemlins/rotfl.gif
  5. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Would the brakes dragging a little cause that? sticking caliper???
  6. TheLakeRat
    TheLakeRat 1/2 ton status
    Nov 29, 2001
    363
    San Angelo, Republic of Texas
    Give me a call at the shop tomorrow. I sent you a PM by the way.
    Whatever it is we'll get you taken care of.
  7. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    i did grind my calipers... so i guess thats feasible... only hole i can see in that theory is that the tires/wheels turn to the passanger side even when the front end is jacked up and the front wheels/tires arent turning at all.
    Im in skool all day today matt, I'll give ya a ring tomorow when i am off. /forums/images/graemlins/smile.gif
    j
  8. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Do you still have your caps that came on the outputs from your steering box when you got it from WTO? If so, disconnect the ram and cap these off. Then try your same test of jacking up the front end and turning. If it continues to steer to the right after you do this, then it has somethign to do with yoru steering box itself. If it doesn't, then it has something to do with the hydro flow from the box to the ram. The other way to do this would just be to disconnect the ram from the tie rod and try it this. But I can't think that is necessarily a good idea.
  9. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    good idear tx... sounds like a smart way to determine *where* the problem is. When i head home this weekend, I'll try it out! /forums/images/graemlins/grin.gif
    j
