WTO mods/ Rear lift shim ?
Discussion in 'The Garage' started by scoutillac, Apr 8, 2004.
  1. scoutillac
    scoutillac 1/2 ton status
    Feb 24, 2004
    423
    Spokane, Wa.
    How is the WTO mod on the road? I have hydro assist on my DD and need more flow at lower RPM's. How does the PS pump mod affect the steering on the highway?
    Also, when I got my 6" lift kit there was a steel shim bolted in the pack. If I take that out will I lose the vibration I have? I am going to put in a 2" lift leaf to level the truck out. I was figuring the shim was to correct driveline angle, but everyone tells me not to run it with a 6" or less lift. What is all of your opinions. I know a guy with 12" of lift not running any shims or mods to the driveline or axle housing. /forums/images/graemlins/1zhelp.gif
    I thought I knew a lot about my truck until I started hangin out here. So much to learn so little time to get the $h!t done.
  2. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    How is the WTO mod on the road? I have hydro assist on my DD and need more flow at lower RPM's. How does it affect the steering on the highway?
    I can't hardly tell I have hydro assist. the only time it lets me know it is ther is at idle, and when i want to turn fast. (i have the big 2" ram.) on the freeway, no probs, between a rock and a hard place--the rock moves. i love it.
    on the shim--i would shim it if the drivline angle is bad---if it is not--dont worry about it.
  3. scoutillac
    Feb 24, 2004
    423
    Spokane, Wa.
    Has anyone else modified their stock PS pump for use with hydro assist? How do you like the high and low speed reactions?
