wto ram question?
Discussion in 'The Garage' started by yunit, Sep 13, 2003.
  1. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Which side of this ram should the high pressure line go to??? I want to get my lines setup before I attempt to start my rig and find out that my lines are in the wrong location.
  2. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    Pete,
    I called WTO and asked the same question.....
    I ended up just leaving one end of the ram unbolted and trying it....(I guessed wrong BTW!) swapped the two lines on the steering box, and all was fine.
    Flip a coin, and connect the lines. Maybe your first guess will be luckier than mine! /forums/images/graemlins/thumb.gif
  3. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    The one that you have connected already should be where the high pressure line goes, its where mine is.
  4. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    I'm sure you are done by now, but both lines are high pressure. Just depends on which way you are steering. I did it like Greg. James.
  5. yunit
    Feb 24, 2000
    3,068
    Oakland, NJ
    My box is tapped the old way, one fitting on top and one fitting on the front of the box.
