WTO/ What did you do to get more power steering fluid?
Discussion in 'The Garage' started by keith, Feb 20, 2003.
  1. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
    Did you add a resivoir or what?
  2. TheLakeRat
    TheLakeRat 1/2 ton status
    Nov 29, 2001
    363
    San Angelo, Republic of Texas
    Actually i don't run anything more than the stock resivior.
    An easy way to add some more fluid it to cut the neck out of another resivior and then use a piece of radiator hose to splice it onto the other one. you can add up to a pint or two like that.
  3. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Add a cooler to it. Kill two birds with one stone that way.
  4. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Im doing both - adding a cooler and adding the radiator hose mod.
    GM Actually offered a reservoir on some of their 1 ton Dually's with Hydro Assist Braking. Wonder if anyone can get a part number.
    Otherwise check this out...
    http://www.pitstopusa.com/POWERSTEERINGTANKS.asp
  5. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    80's gm vans had a reservoir on them to should be easy to modify I haven't got around to putting mine on yet but should be soon. I have a cooler to may put it on too.
