Wuz A K5 UPDATE 12/12 w/Pics
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DBLAZER, Dec 5, 2002.
  1. DBLAZER
    DBLAZER 1/2 ton status
    Apr 2, 2000
    1,716
    Haslet, Tx
    Yes folks, that's right. The "K5" is back in the shop and finally on the home stretch. The last time I posted anything it was with the pictures of the bobbed rear end. It then sat for about 6 months while I got the money and comps together to finish it up.
    About two weeks ago, we (JUSTIN HOLT @ Rocktek Engineering) and I pulled the K5 into the shop and got back to work.
    The first thing on the agenda was the removal of my old 14bolt FF (which is for sale BTW for 350$) and the removal of all the springs and hangers and such. We then cut off the 35 some odd inches of frame that was protruding from the ass and of the rig. We pulled the new 14bolt in and put about where we wanted it. We then set about pulling my Atlass so we could install the KLUNE V. we wanted this so we could determine how far back I wanted to push the axle. The Klune is supposed to push the tcase back 6 inches. Well, with the adapter and the "foot" it totals out to about 7.5". So we got it put together, and back in the truck. I will give a more detailed post on the Klune later on down the line if yall like. But for now I will say this.
    When I received it I was very impressed with the product. The Klune itself is a very cool looking piece. They have put a whole lot of time into engineering this thing. The directions, well, they lack something to be desired. I was unimpressed by the lack of goo pictures and the way the directions did not apply to my applications at all. The install took us a couple of hours, but a lot of that time was spent deciphering the pictures and directions. Understand this, I know most people say I don’t need the directions, however this is a very expensive piece a machined aluminum, and I wanted to make sure it was done right.
    With the Klune in we decided to push the rear axle back 6". We measured and measured and measured again and then we set the axle in place and got to work fabbing the upper coil buckets into the rear frame. Justin had already prebuilt the upper and lower coil mounts. We decided to mount the rear buckets IN the rear frame, so we notched the frame, mounted the upper mount and the set out to boxing the frame back in so it would have strength. The lower control arms were built and installed. We used forward leaf spring mounts as the upper mounting position on the frame. The upper arms were then fabbed up and built. We used a thinner DOM tubing for the upper arms because of the way we bent them and ran them up to frame. They are basically a y with the open end arms mounting on the frame and then coming up to the center and forming one arm that is mounted on a new crossmember with a 1.25" heime joint. We then installed the Skyjacker 8" Coils.
    With the rear all done we used a fork lift to twist it up and well, let me say that I am very excited to get this thing out on the trail because it all seemed to work very well.
    With all that done, Justin put some very serious time into the belly skid and the new crossmember that we were going to need to support the 700r4, the Atlass and the Klune. It is hard to describe what the new belly looks like, but put simply, it is very tucked up and very smooth and very COOL!!! It has a very flat center section now that will slide up and over anything!!!
    With that done we turned the truck around and last we set to taking it all apart we removed the axle, pulled the leafs, and removed what was left of the core support.
    As it sits now, the radiator is al that is left up front. I am going to lower it two inches and tuck it in closer to the engine. I am trying to achieve as much visibility as I can. We sat and stared at it last night for hours planning and playing with my "new" Ford Taurus headlights. I think we have it figured out which direction we are going to go and how the front will look. I think.... That’s all for now, I gotta run!!!!
    You can see more pics at my WEBSHOTS PAGE
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Re: Wuz A K5 project UPDATE!
    Okay, what is a "Klune" ???? Also PICS !!!!!!!!
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    The Klune-V is an overdrive or underdrive unit added to the tranny/t-case combo to do just that...give you more power or more cruising range. There are options between them when deciding what you want to use it for. They are also costing a pretty penny to buy, too.
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Nashu, is there anything left that is still an identifiable GM part on your truck? /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  5. DBLAZER
    Apr 2, 2000
    1,716
    Haslet, Tx
    The CAB!!!!! pretty much kinda sorta!!!!
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  7. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    awesome truck!!!
  8. a2b
    a2b Registered Member
    Dec 3, 2002
    17
    L.A.
    never seen a bobbed k-5. pics would be great /forums/images/graemlins/thumb.gif
  9. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    The Klune is a planetary reduction box...a doubler of a different kind. 2.72 low range and 1:1 high range using a NP241 planetary set.
    You might be thinking of the Gear Vendors under/over drive unit Wes.
    Rene
  10. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    WE DEMAND PICS!!! /forums/images/graemlins/thumb.gif
  11. UNCLE CRACKER
    UNCLE CRACKER 1/2 ton status
    Dec 29, 2001
    937
    PORTLAND OR
    sounds sweet, lets see some pictures.
  12. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    click my webshots in my sig...although mine's not as hacked as nash's...it's one of the first bobbed K5s in existance.
    Bryan /forums/images/graemlins/rotfl.gif
  13. laketex
    6,220
    North Texas
    actually now that i think about it, it's actually probably almost as hacked as nash's.... /forums/images/graemlins/grin.gif
  14. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    you can gert klune Vs down to 5.3:1!!!!!
    imagine a 5.3:1 klune and a 4:1 doulber behind a PAIR of 465s!!! /forums/images/graemlins/ooo.gif /forums/images/graemlins/ooo.gif /forums/images/graemlins/ooo.gif /forums/images/graemlins/ooo.gif /forums/images/graemlins/ooo.gif /forums/images/graemlins/ooo.gif /forums/images/graemlins/ooo.gif /forums/images/graemlins/ooo.gif /forums/images/graemlins/ooo.gif /forums/images/graemlins/ooo.gif /forums/images/graemlins/ooo.gif /forums/images/graemlins/ooo.gif /forums/images/graemlins/ooo.gif
  15. laketex
    6,220
    North Texas
    hello class, can we say overkill???
    imagine it with a manual and 3:1 gears in the 203!
    6.55 x 4 x 3 x 1.96 x 5.13 axle = 790:1 crawl ratio.
    and hey, if that wasn't enough, you could get 3.33:1 portals
    PORTALS
    And then your crawl ratio would be 2631:1, rounded down /forums/images/graemlins/eek.gif
  16. DBLAZER
    Apr 2, 2000
    1,716
    Haslet, Tx
    /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gifListen folks, I have been very busy BUILDING, not taking pics. I have had a year of pictures, I am reaady for the real thing. /forums/images/graemlins/tongue.gif /forums/images/graemlins/tongue.gif
    OK, I will get some pics up this weekend, either here or at Rocktek.ws wich byu the way already has pics of the bobbed body on it. I will get updated shots ASAP!!!
  17. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Man... Nash you've been a busy person lately..
    Nice work.. I like your truck now. but I drooled over it when you wheeled with us at the Slab along time ago..
    Can't wait to see the completed project. /forums/images/graemlins/thumb.gif
  18. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    Dude thats sweet /forums/images/graemlins/thumb.gif. I really like the box under the seats. That looks like a good way to fix a floor /forums/images/graemlins/grin.gif
    As for the rest of the truck...I wish I had the balls to do that to mine . /forums/images/graemlins/ignore.gif
  19. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    I got to see this "thing" the other day---this thig is awesome. the way the rear is made is real trick and excellent fab work. Nash is a cool guy to boot /forums/images/graemlins/thumb.gif some day ill have to show you around Las Cruses.
    p.s. I think you're gonna have to change something in your sig. /forums/images/graemlins/pimp1.gif
    It used to look like this /forums/images/graemlins/k5.gif
    now it looks kinda like this--> [​IMG]
  20. DBLAZER
    Apr 2, 2000
    1,716
    Haslet, Tx
    OK I added Pics!!!! DANG!!!
