Wwhat is this? I think i destroyed it.
Discussion in 'The Garage' started by n8brown, Mar 14, 2006.
  1. n8brown
    n8brown Registered Member
    Dec 8, 2005
    23
    Portland, OR
    So i was putting my new alternator in. When i put the wire that fits on the bolt in the back on it started sparking. then, something on the firewall started sparking and made some noise and then smoked. I THINK it was this but what the heck is "this?" Also, how screwed am i?
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    probably just burned up a fusible link.
    find it and replace it.
    next time disconnect the battery when changing the alternator.
  3. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    the "this" he is referring to is the following picture.
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    this is just the junction block for the power
    still next time disconnect the batt first
  5. wildmouse216
    wildmouse216 1/2 ton status
    Dec 26, 2005
    135
    Rifle, Colorado
    I agree fusible link fried. This is like a circuit breaker in the wire that chevy put in. I don't know what for but they are hard to find if you don't know what to look for. The insulation on the wire will be a little blackended and look melted but will most likely still be on. Happy hunting.
  6. n8brown
    Dec 8, 2005
    23
    Portland, OR
    so the thing in the picture has nothing to do with it?
  7. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    thats where the fusible links connect to.
  8. chevyin
    chevyin 1/2 ton status
    Sep 14, 2005
    1,324
    Pismo Bch CA
    They are a resistor for the coil. Chevy use to use a piece of wire a certain gauge and thickness (to gain a certain resistance), now GM uses (well when your truck was new) a 'fuseable link', the thing you smoked. ;) Just go get a new one, im sure your local PepBoys/AutZone will have them.
  9. n8brown
    Dec 8, 2005
    23
    Portland, OR
    oh man i hope so. so after all that happened i connected my batteries to try and start my truck so i could move it and nothing happened. No electricity. That problem is becuase of the fusable link?
  10. chevyin
    Sep 14, 2005
    1,324
    Pismo Bch CA
    I would think the truck would still turn over without it, just run poorly, but Im not sure. Dont think Ive ever had a bad one. ;)
    edit: on second thought, you probably aren't getting any current to the coil if its actually fried, so ya that would make sense.
  11. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    for what it's worth, he's got a 6.2L
  12. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    The fusible link is there to protect the rest of the electrical system in case of a short like you caused. It is basically a short length of wire about 2 or 3 sizes smaller than the rest, designed to allow normal operation but melt first if there is a short. With a blown fusible link you won't have power to much of anything...
    Rene
  13. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    to add to his story, he had the battery disconnected before this happened, but when he reconnected the battery, that's when this occurred. recently, his batteries only last about a week or two before they need a recharge (not the reason he changed his alternator tho - it tested good, just had broken fasteners). I was thinking maybe there's a leak in his electrical system, and that's what initially caused the sparking. could this aid in his search for an electrical leak?
  14. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    I roasted the fusibile links in my trail truck one time (it has a 6.2 with a gasser wiring harness) and i would not make any indication of life when I tried to crank it. The insulator between the alternator case and the positive output stud on his alternator might be bad, and cause the short. Is the stud loose or wobly?
  15. dyeager535
    26,980
    If you fried the link(s) on connecting the battery, that's a fairly good indicator that something is wrong in the electrical system, and probably also likely what the problem is with the battery charging issue.
    If sparks came from the junction block pictured, you might want to double check that the fusible links are actually bad, and that something isn't going on with the other component hooked up to the block. It almost looks like there is another wire hooked up to the junction block going to the other side of the firwall?
    You will also need to test to see what kind of draw there is on the battery when the truck is turned off. But *if* it was enough to burn the fusible links, it would be enough to burn the fuse out in whatever you use to test draw.
    Probably can't hurt to pull the nuts off the junction block and clean up the terminals on the wires, they look a little corroded, plus if you are going to check the fusible links...
  16. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    just to expand on dorians good advice...
    if you think you have a draw, turn the key to off, disconnect the ground for the battery, put a testlight between the post and disconnected cable. it should light if you have a draw.. you can isolate the prob by then pulling different fuses till the light goes out..
    also, when electrical connections fail, a prime culprit is often the end connectors.. corrosion and movement tend to make these the weak links... often it is a good idea to cut the wire back a couple inches to fresh meat and solder up a new connector...
    definitely sounds like a fusable link in your case, but thats something to look out for at places like that junction block, starter wires, etc...
  17. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You have been misinformed... :rolleyes: You won't find a resistor for the coil on a GM newer than '73 or so. A fusible link is a piece of special wire that is calibrated to burn in two at a specific current (just like a fuse would, hence the name "fusible" link). It is covered with a flame proof insulation to prevent starting a fire when the fusible link gets toasted.
  18. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    the infamous resistor wire... :wink1: i remember my bud having fits with his 70 Chevelle after installing an MSD cuz of the wire, need that full 12 obviously... very obviously a different style wire when you look at em with that cloth-like covering they had.. seen them give people fits on a few occasions... :doah: :haha:
  19. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Chrysler used a big, ceramic resistor back then, that would burn out on a regular basis. The engine would start (resistor was bypassed in "crank" mode), then die immediately when you released the key. Everyone I knew that had a Chrysler product kept a spare resistor in the glove box. Great design... :rolleyes:
  20. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    haha, yup, i grew up a Mopar guy.... :D
    you can add torsion bars to that list of wonderful engineering too imo.. :haha: once i went Chevy with coils i was like what was Mopar thinking with that one... :doah:
    tho i always liked the shaft mounted rockers... ya could really spin up some rpm's with them....
