x-fer case speedo leak
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 71 Blazer, Mar 12, 2006.
  1. 71 Blazer
    71 Blazer 1/2 ton status
    Jul 16, 2005
    184
    windsor virginia
    my transfer case is leaking at the speedometer. I went to GM for a new seal. I put it in just like the old on it still leaked. Where on that shaft does the seal go? All the way back? I asked the GM guys but they didn't have any books on trucks that old. Am I missing a piece? All I have is a shaft with a gear on it, a seal and the nut piece that screws into the transfer case.
  2. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
  3. jaros44
    jaros44 1/2 ton status
    Jul 12, 2005
    408
    Outside Phila. Pa.
    Good advice, no I didn't know that!!!Thanks I will try to save that. Later J.
  4. 71 Blazer
    Jul 16, 2005
    184
    windsor virginia
    Does that mean that I have to buy a new sleeve, or can I just get a new gasket?
  5. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Not sure if you can get just the gasket.I believe it's more than just a O-ring.
  6. 71 Blazer
    Jul 16, 2005
    184
    windsor virginia
    I'm going to go to GM tomorrow and see what they can do for me. The part number to the sleeve should help. Thanks
  7. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
  8. 71 Blazer
    Jul 16, 2005
    184
    windsor virginia
    I went to GM today and no one in my area has one in stock and its a special order. Does anyone know for certain that when you order the sleeve it comes with a seal? I just want to find out for sure before I order an item I can not return.
  9. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    It's all one piece.
    You get the steel sleeve with the seal allready installed.
    That's how it came when I ordered mine anyway.
  10. 71 Blazer
    Jul 16, 2005
    184
    windsor virginia
    Thanks a lot. That would explain why mine leaks. I think the PO just put some sort of seal in there.
  11. 71 Blazer
    Jul 16, 2005
    184
    windsor virginia
    Thanks everyone for your help, I got that piece in the mail today and it is exactly what I needed.
  12. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Sometimes even my "simple tech writeup" seems to be the most appreciated!!
    It took me a long time to find that part, so I'm always glad when someone else can solve the same problem SO much more easily!! :thumb:
    If you need "tech" on how to remove the ignition tumbler and trim ring.....let me know, I've got that one perfected also. :haha:
  13. ecameron87
    ecameron87 1/2 ton status
    Nov 9, 2002
    115
    AZ, Tucson
    I used Greg72's write-up as well. I had to order the part. At first I thought that this sleeve didn't fix the problem because it still leaked for two days after installing it. I found out that there was a lot of oil in the speedometer cable and the tiny gearbox and it was draining out. So you might want to clean those out and grease them properly
