X-Members - Rear 67-72 and front 91 Sub or equivalent
Discussion in 'Parts & Trucks Wanted' started by JungleBoy, Jan 6, 2002.
  1. JungleBoy
    JungleBoy 1/2 ton status
    Jan 31, 2001
    243
    Houston TX
    Looking for a mint condition rearmost x-member for a 67-72 truck, the one the fuel lines bolt to on a Blazer and through which run the rear wiring harness.
    Also, a front x-member like is on the 91 V1500 Sub, with the mounting pads for the stabilizer bar attached to the x-member (not the hang-down brackets riveted to the bottom of the frame).
    I'm in Houston. Thanks
    JB
  2. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    JB, i got the xmember. i took it off my blazer when i did my 31 gal conversion. make me an offer + shipping(from 92243). it has surface rust but can be wired off.
    ARQ.
    offroad baja!!!
    72 4x4 CST Blazer
    71 4x4 CST Blazer
    <a target="_blank" href=http://coloradok5.com/gallery/ArqDennis>My Pics</a>
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    all sway bars on trucks use hang downs for the two front most bushings, i have a 85 3/4 2wd burb out here im getting ready to cut up soon if theres anything you can use off it. selling cheap
    '72 K-5 4x4, CST, 3.07, 4 speed, NP 205, 31' x 10.5", converting to 2wd and pickup body(I did not want to do this- rust made me do it)
  4. JungleBoy
    Jan 31, 2001
    243
    Houston TX
    My 91 Sub has some neat pads riveted to the front crossmember from which the stabilizerbar is hung. However, if you have the hang-down brackets undamaged and cheap, I can sure use them.
  5. JungleBoy
    Jan 31, 2001
    243
    Houston TX
    Arq
    If it is not dented or dinged, I would pay 25 bucks plus shipping.
    JB
