x-over drag link angle.
Discussion in 'OffRoad Design' started by southernspeed, Feb 18, 2006.
  1. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    How parallel should the drag link of an ORD cross over set up be to the axle? With a stock 2wd pitman arm and EZRide 4" springs mine's sitting at a slight angle. Is this going to cause bump steer problems?
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I have the ORD crossover steering with the bent draglink and it is at a slight angle and no problems. :thumb:
  3. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Cool, thanks. Did you have any problem with spring to tie rod clearance? I had to put a 1/2" zero rate in to get clearance and I'm still a bit concerned about it when on full left lock. This is on a 10blt with D44 knuckles and the tie rod on top of the knuckles.
  4. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I can't answer your question as i'm running a D60 up front.
