X-over guy's NEW ??
Discussion in 'The Garage' started by captain chaos, May 14, 2003.
  1. captain chaos
    captain chaos 1/2 ton status
    Mar 29, 2002
    413
    dickinson, north dakota
    X-over guy\'s NEW ??
    sent my 2wd sector to matt (WTO) and had him rebuild and port it.
    put it on, went lock to lock counting turn's. found center went to put pitman arm on.
    one way it is pointing about where the fender meet's the firewall and the other way it is pointing at about the bell housing. so ether way it is not straight with the frame rail.
    is this right? or does this even make sense..
    thank's
    dave
  2. Shagnaz
    Shagnaz 1/2 ton status
    Jul 19, 2002
    308
    South Carolina, North Charleston
    Re: X-over guy\'s NEW ??
    Get back in touch with Matt. That is not right.
    /forums/images/graemlins/thumb.gif
  3. captain chaos
    Mar 29, 2002
    413
    thank's /forums/images/graemlins/thumb.gif
    i thought maybe this could be right or i did somthing wrong.
    i'll pm matt.
    dave
  4. TheLakeRat
    TheLakeRat 1/2 ton status
    Nov 29, 2001
    363
    San Angelo, Republic of Texas
    OK here is the deal some pitman arms are clocked different than others. Iv'e sen some up to 15 degrees off for a sertain application. So what did you get yours from?
    There are 4 double splines on the sector shaft. when the steering is centered they should point to the front, back left and right. The pitman arm will have 4 blank splines to keep the pitman arm aligned correctly.
    If you used a Ford pitman arm it will be 45 degrees off ffrom where it needs to be.
    Now there is only one way for Saginaw boxes to go together.
    I guess i could have assembled it wrong but i hope that i would have caught something like that during testing. But i have made mistakes before.
    Give me a call and we'll get it figured out.
  5. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Service with a smile!! Gotta love that support!!
