x-over, hi steer and hydraulic installed.....Death wobble?
Discussion in 'OffRoad Design' started by ZK5, Sep 29, 2004.
  1. ZK5
    ZK5 1/2 ton status
    Dec 16, 2001
    100
    Meriden, CT
    I recently installed the crossover steering, hi-steer and hydraulic assist for my 60 and I finaly took it for a test ride. As soon as I hit 25 mph or the first bump the truck wobbles so hard that it yanks the steering wheel out of my hand. I replaced the king pin bushings and washers only cuz I had new ones layin around it didnt help at all. The pins looked good and I dont get any play from the lower bearing and pin. I aligned the front wheels the best I could with a tape measure and they appear to be right on. Should I invest in the complete king pin set or a 4 wheel alignment first?
  2. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Try adjusting your front wheel bearings. I had one side out of adjustment and it did this.
  3. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    /forums/images/graemlins/shocked.gif
    Whoa, this happen to anybody else? I thought crossover and hydro assist deleted the death wobble problem. Death wobble is the main reason I was going to crossover w/hydro assist. /forums/images/graemlins/shocked.gif
  4. funkycold
    funkycold 1/2 ton status
    Apr 22, 2002
    435
    Orange County, CA
    What about tie rods ends? I had this same thing with my crossover (not a d60) and had the front wheels balanced and it helped dramatically.
  5. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    all the above plus check the toe again, you should have some toe in, probably 1/4" or so wouldn't hurt to try.
    Maybe try with different tires to see if it changes?
