x-over/hysteer question: drag link to tie rod? good or bad?
Discussion in 'The Garage' started by txbartman, Jan 7, 2003.
  1. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    X-over uses steering arm on passenger knuckle (D60). Hysteer usually uses a passneger side arm with 2 holes (one for tie rod, one for drag link) with another arm mounted on the driver's side. But, when moving the axle forward, I have potential interference between the tie rod and drag link connections on the passenger side arm at full turn (especially right turns).
    Why not use the factory D60 tie rod as the tie rod. Flip it over so the original stabilizer hole in the tie rod is on the passenger's side. Drill this hole out some and attach the drag link to the tie rod? There would be no interference problems that way. I also would increase the angle some of the drag link preventing interference with the engine cross member but would still gain significantly from a non-xover setup.
    Thoughts?
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    I was wondering about this myself.
    ford ran it like this. since you are moving the axle fwd then you can put the drag link on the back side of the tie rod to compensate a bit. i dont see why it would be bad. you could use a heim joint on the drag link end connecting to the tie rod.
    Grant
  3. tRustyK5
    Jul 23, 2000
    36,184
    1,391
    E-town baby!
    I'd think you would have the potential to bend the tie rod then...especially in the rocks!!
    Rene
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I know the Hi-steer arms that I have, The stock Tie rod is way to long. It would have to be cut down to work. Maybe you could ask Dr. Watson (ORD). I bet he would have a good answer.
  5. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    What hi-steer arms are you running?
