X-over pitman arm DLE
Discussion in 'The Garage' started by BDAMNRZ, Feb 14, 2007.
  1. BDAMNRZ
    BDAMNRZ 1/2 ton status
    Aug 9, 2006
    124
    Chesterfield, VA
    So I got the 1104 arm from WFO. I was not sure if I was going to run the GM DLE on my drag link or use TRE's. I decided to go with DLE's for the angularity. Now I have to re-taper the pitman arm to fit the DLE's. I have the tapered reamer but man is that arm hard. I cant seem to scratch it. I have heard that ORD sells a TRE with the angularity of a DLE that will bolt right up. Is that correct? If not, where can I get the arm re-tapered? I dont want to burn up the reamer because I still have some cast stock pieces to mess with. :crazy: :crazy: :crazy:
  2. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Go with ORD's TRE, that is what I am running
  3. BDAMNRZ
    Aug 9, 2006
    124
    Chesterfield, VA
    So the info is correct (it has the same taper dimension as the TRE but the angularity of a DRE) That would really be great! Anybody else?
  4. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    I don't think it has the angularity of a DRE, but is plenty good enough for most applications.
