x-over riser block is it needed?
Discussion in 'OffRoad Design' started by pilgrim, Jan 1, 2002.
  1. pilgrim
    pilgrim 1/2 ton status
    Sep 10, 2001
    247
    new hampshire
    i installed my x-over this past fall and i love it , thanks. But i was wondering if that riser block is needed. i have only a 6" susp lift and thought that it was ok without it , however i must have ordered it wrong because i got one. so hey, i put it in. does having it in put unecessary stress on the knuckle. also i'm having very nasty handleing (death wobbing) but i have agr dumb box so i haven't ruled that out yet. thanks for any input.
    85 sub / 350 rebuilt / 14bolt ff ,w-detroit/ dana 60 w-posi / sm 465 / np 205 / 6" lift / 10000 ramsey / custom tailgate
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Not so sure you got the spacer block from us, I don't know that we've ever sold one! For a 6" you shouldn't need the block, just bolt the arm to the knuckle and you should be fine.
    for the DW, look to castor angle and check the condition of all the steering joints and wheel bearings. Also, if you don't have a stabilizer, get one, it doesn't take much of a stabilizer to really help out.
    Making the world better, one truck at a time.
    SW-ORD
    <a target="_blank" href=http://www.offroaddesign.com>www.offroaddesign.com</a>
  3. prjt_blzr
    prjt_blzr 1/2 ton status
    Mar 4, 2001
    352
    COS, CO
    Also for the DW check the front spring mounts to make sure that they are very tight to the frame. Mine were loose and scared the PI$$ out of me at 65MPH.
  4. pilgrim
    Sep 10, 2001
    247
    new hampshire
    sorry your right i bought it from oru not ord. but thanks for the info i really appreicate all the help you guys give. i hope to have this DW figured out today.
