x-over steering arm
Discussion in 'OffRoad Design' started by 84K5cedric, Jun 17, 2003.
  1. 84K5cedric
    84K5cedric 1/2 ton status
    Aug 2, 2002
    279
    Austin, TX 78660
    Can someone explain to me or maybe post a picture explaining this blurb? I copied it from ORD's website...
    The Offroad Design D44 steering arm end is cut on an angle to correct for the kingpin axis inclination angle and keep the angle on the rod end minimized for best life of the joint and more vertical wheel travel without steering bind. We've attempted crossover steering systems using arms that aren't built with the angled end and the rod end was maxed out at ride height! No droop available at all. This is an essential feature for a properly built fully functional system.
  2. Lance
    Lance 1/2 ton status
    Mar 4, 2002
    606
    Birmingham, Alabama
    Instead of your TRE being at a severe angle where it mounts on the "straigh-cut" steering arm, ORD has machined in an angle to their steering arm to reduce/eliminate angle of the TRE. Thus improving the TRE's longevity and improving "droop" in off-road situations. I'm sure there are other benifits and more detailed explanations, but that sums it up in a nut shell.
    Lance
  3. 84K5cedric
    Aug 2, 2002
    279
    Austin, TX 78660
    ok, so that would only affect the draglink right? so wouldn't the bend in the drag link help that?
  4. Lance
    Mar 4, 2002
    606
    Birmingham, Alabama
    To an extent, but the straight draglink is ideal.
  5. chevystepside
    chevystepside 1/2 ton status
    Sep 23, 2002
    147
    leadville colo
    I,M GOING TO MACHINE THE TOP OF MY KNUCKLE MY SELF AT WORK WITH A MILL. MY QUESTION IS CAN I JUST BOLT THE KNUCKLE DIRECTLY TO THE MILL BED AFTER REMOVING THE UPPER AND LOWER BALL JOINTS? OR DOES THE KNUCKLE HAVE TO BE MILLED AT AN ANGLE? sorry about the caps just realized caps lock was on after i posted, my bad.
  6. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    We cut them true to the ball joint centerline. That may or may not be true to the bottom of the casting.
  7. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    That is exactly what i do, i even went so far as built a fixture to hold them true /forums/images/graemlins/thumb.gif
  8. sageman
    sageman Registered Member
    Sep 27, 2002
    40
    Calgary, Alberta, Canada.
    Do you mean perpendicular to the axis of the ball joints? And is the ball joint axis paralel to the spindle mounting face?
  9. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Yes and no. How's that for concise.
