x-over steering kits
Discussion in 'The Garage' started by mollyman, Apr 3, 2007.
  1. mollyman
    mollyman 1/2 ton status
    Aug 18, 2006
    280
    west virginia
    Anybody out there know where I could find a complete crossover steering kit? One that includes the knuckles. Or does one even exist? It will be for a 3/4 ton 10blt. Any help would be great. Also has anybody tried going full hydrolic steering on a 10blt? Any experiences would be great. THANKS
  2. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    If you need crossover/hydro, you might want to consider upgrading that 10b.
  3. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    cbbr you are refering to the hydro part and not the x-over part correct?
    Reason I ask is b/c x-over would be useful just b/c of the amount of lift...like me...I'm on 8" of lift and still running a 3/4 ton 10b which is more than enough axle for what I do yet I still could benefit from x-over. iono I just didn't see the correlation between x-over and having to go d60.
  4. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    1/2ton and 3/4ton 10b are the same, no strength difference. i think he was referring to the hydro part. if you are going to actually need hydro steering, chances are your tires are going to be over the limit of a 10b. even hydro assist for that matter.
  5. cbbr
    Jul 17, 2004
    14,681
    Really either. Hydro and Crossover are both for rigs with big lifts and big tires that are used offroad. A 10blt is not. It may work for a while, and yes we have this debate all of the time, but it is really not designed for a rig that needs crossover or hydro IMO.
  6. mollyman
    Aug 18, 2006
    280
    west virginia
    I have an 81 k10 sub with 3" lift in front and 4" lift in back. Running 34x10.5 tires. The rear is a 14blt ff the front is a 10blt 3/4 ton. The front is open diff. I can't afford a d60. So you guys don't think I need to change to cross-over steering? I will be putting in a locker sometime in the front. Well should I even do the convertion? I just thought it couldn't hurt but if it is not worth the money, let me know your opinions. THANKS
  7. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    id stay away from a locker in the 10b. really if u want a front locker you really should get a 60. 10b locker + big tires = lots of broken shafts. save that money for a d60. with only 3" lift up front stock steering is fine. you cant do cross-over without at least 4" lift i believe. you would end up spending a ton of money to get the flat top knuckle and getting it machined plus the arms. better off keeping what you got now and save up for a 60. then get cross-over and a locker
  8. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    parts mike has everything
  9. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    134
    Fixed it for ya
  10. cbbr
    Jul 17, 2004
    14,681
    Yep. But there are not that many of those rigs that have the perfect combo of a low COG and lots of flex. I'm working on that now...
  11. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    If your truck flexes good and you want to be able to turn while on the trail you need X-over, even if you are just running 35's and 4 " lift.
    Don't go Hydro without X-over, if you are flexed out the hydro would tear your stock steering apart.
  12. 1977k5
    May 26, 2003
    9,995
    134
    Back when I had push/pull steering, my 4" BDS springs would flex enough that when flexed out and at full crank left, the tires were still pointed a little to the right. Crossover made it so the truck turned perfectly both ways, I didn't even notice a difference with the truck flexed out or not.
    BTW, I plan on dropping the suspension ~2" and having significantly more flex than I have now later this spring. Even with the truck only a couple inches over stock I would never be able to run anything other than full hydro or crossover.
    I think that crossover is more important on a flexy suspension than a tall one. 8" lift and over shouldn't even consider push/pull steering, IMO.
  13. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    if you are only going to have ~2" lift i dont think ull be able to run cross-over. your best bet would be full hydro:D
  14. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
  15. 1977k5
    May 26, 2003
    9,995
    134
    We'll see. It is going to be close especially since I am moving the front axle 3" forward. I will probably end up with almost no uptravel via bumpstops.
  16. Stump-a-holic
    Stump-a-holic Registered Member
    Mar 21, 2006
    29
    South Wales, NY
    Do they not have it in kit form? Or am I just a numb skull :doah: and cant find the kit on their site?
  17. 83L98blazer
    83L98blazer Registered Member
    Feb 18, 2005
    27
    GA
    I can't find it either. Has anyone purchased a x over kit from diy4x?
