X over steering on 2.5" lift?
Discussion in 'The Garage' started by stallion85, Jun 28, 2004.
  1. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    X over steering on 2.5\" lift?
    Can you run X over with 2.5 spring lift in front? Dana 44.
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Re: X over steering?
    Sure, if you replace your engine crossmember.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Should be able too. You may need a replacement engine crossmember or trim yours. Moving the axle forward might help it clear too. A bent draglink will probably be necessary too.
    Harley
  4. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    I assume I can use the ORD add a leaf to move the axle forward and trim the engine crossmember. Would I need a new front drive shaft if I move the front axle forward? Is there different engine crossmembers that you can buy or is trimming the only option?
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    You can buy the Missouri Offroad Outfitters unit. Problem is they recommend it for minimum 4" lift and I've heard grumbles that that may be a bit close for comfort. If you add a zero rate you could come into drag link to leaf spring interference issues. Someone else may have a better idea but I could see that being an issue with only 2.5" of lift anyway.
  6. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Anybody have any other tips for me. Could I do it with 2.5" and a shaved crossmember or do I need a 4" lift?
