X-over steering question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Brian 89KBlazer, Mar 22, 2001.
  1. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    Two questions actually:
    1. What years of 2wd steering box can I use on my 89 Blazer for crossover steering? '80-??
    2. Is 1500lb load rating enough for a rear wheel on a Blazer? The Eagles & Mickey Thompson cast wheels are 2800-3300lbs!!
    Brian
    89KBlazer
  2. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    I kept my 4x box. I just swapped the shaft out with the box still on the vehicle. It was cake. Easier than removing the box anyway. I think the shaft I used was out of a 83 2wd.
  3. Brian 89KBlazer
    779
    Ontario, Canada
    Thanks Toby
    Just re-read Depdog's x-over article and maybe that's what I'll do to save some $$. My 4wd steering box looks to be in ok shape.
    Brian
    89KBlazer
  4. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    :D i just used the one that had the correct steering pump fittings..
  5. bp71k5
    bp71k5 3/4 ton status Premium Member
    Mar 31, 2006
    6,239
    284
    San Jose, California
    I think you want to make sure (if you swap) that you get the 86+ box since they changed to variable gear thingy that's different from earlier types. My 71 has the early type and the box is really too loose compared to modern steering boxes. I'd just get the same year 2wd box as your 4wd.
  6. mrk5
    Apr 20, 2004
    12,343
    1,047
    Northern Colorado
    It's great that you guys are offering up such useful advice, but I'm afraid it may be a little too late. Considering this post originated in '01. :doah:
  7. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    My......doesn't time fly!:D
