X over Steering Question
Discussion in 'The Garage' started by ssped, Sep 25, 2006.
  1. ssped
    ssped 1/2 ton status GMOTM Winner
    Jan 5, 2006
    1,529
    Mission Viejo
    I was at a local Fab shop today and was looking at a heep they had sitting there. The Xover steering arms on there had heim joiints and on the rt side knuckle they just doubled it up. one on top of the knuckle and one on the bottom using the same hole. Why dont we do that on ours? why do we use the flat top knuckle?
    Just asking.
  2. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    Can you snap a picture of it and post it up for us to see?
  3. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    134
    Heims wear out very fast compared to OEM style ends.
  4. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    If you tried to use a x over draglink straight to the knuckle on top of where the tie rod goes you would have to remove your leaf spring. Was this Jeep spring under? The reason you have to get an arm is to get the dragling above the springs.
  5. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    I know what he means by doubled up. Two heims sharing the same bolt and mounting hole. When force hits the draglink to push the arm one way, the tierod will be pulling in the other direction. This is just as bad or worse as a single shear/single heim setup. Gonna hog out your mounting holes in no time. Not a good way to do things IMO. Any good engineer could look at a single shear setup like that and tell you that those holes are gonna hog out over time. Having them stacked twice as high puts even more stress on the bolt and mounting hole, double! Force * Distance...
    I'll take a good ole tapered TRE or DLE myself. Much more longevity.
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Heims suck on anything that is going to get road use.
    Harley
  7. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    the reason it works is either the jeep is spring under or coils. spring over leaves interfere with the drag link when it is mounted to the tierod mount. I also agree with everyone else in that that setup is going to wear out. and if that single bolt fails not only will you not be able to steer but the front tires will not even point in the same direction. That could be really bad on the road.
