X over steering?
Discussion in 'The Garage' started by stallion85, Jul 8, 2004.
  1. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    On the stock pitman arm on 2WD steering boxes, will this work with X over? I have read that there are different types that will work. /forums/images/graemlins/dunno.gif
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Not the stock Chevy pieces. You can use the Superlift #1104 arm for Ford's or you can use a Jeep arm. I don't remember which one offhand though. I use the #1104 arm. It works great.
    Harley
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Stock Chevy 2wd arm is a wearable part with a tapered stud. The aftermarket setup is a tapered hole for a tie rod end and this is why you cannot use a stock 2wd arm with crossover. You need a hole, not a stud.
  4. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    The axle I just purchased is a D44 with an ARB, Chrom-moly shafts, CTM u joints, and X over steering. The PO had a hydraulic assist setup on it, so the welded tabs are already there. My question is would you guys go ahead and get the hydraulic setup if you were me? I looked into West Texas Off Road and it looks like I could get a box fitted for $150. I would then need to buy some lines and a ram. Are the rams really that expensive? Could I buy one from a different source, if so what type would I need. Let me know what you guys think /forums/images/graemlins/whistling.gif
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I've researched rams locally and they're more expensive than WTO.
    If you can afford to go hydro assit, do it now!! It will save your frame from carnage.
  6. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    im planning on going hydro assist too.. before my truck goes on the road in 2 months... (I KEEP ON SAYING 2 MONTHS!!! HEY WIFE IS IT 2 MONTHS YET????!!!)
