X-over steering. ??
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by POWERMAD, May 7, 2005.
  1. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    I'm replacing the ball joints and having the knuckle machined.
    I have a 73 2 wheel drive steer box, do the box's interchange between the 1st and 2nd gen's?
  2. Ryan B.
    Jul 18, 2001
    5,693
    CA
    I believe they do. You just have to watch out for newer trucks like above 89 some of the steering boxes are metric fittings.?
    I looked at my steering box and walked around the junkyard, found a 2wd version that looked the same out of a 77 or 79 chevy truck. It swapped right in, the only thing that was not the same was the rag joint.
    The rag joint diameter where it bolts onto the splines of the steering box are bigger for the 4wd and smaller on a 2wd box. Be sure you grab a 2wd rag joint with the steering box so everything bolts right up.
  3. POWERMAD
    Mar 4, 2001
    3,466
    Oregon
    I have the pump and lines to go with the box, looks like I need to get a rag joint now. Should be easy enough to get one.
  4. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    Pull the sector shafts and compare. Might be able to just swap out the sector from one box to the other.
  5. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    you can, that's what I did with mine, My rag joint blew so I replaced it with a ujoint. then did the crossover but the input on the new box was different.
  6. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    They interchange, like said above. Mines off a 76.
