x-over steering
Discussion in 'The Garage' started by tightwad, Jun 26, 2006.
  1. tightwad
    tightwad Newbie
    Dec 7, 2005
    Weatherford,Tx
    do i really need x-over steering or can i use a 2wd gear box and 4" drop pit arm ??????? my ride is 86' k-5 w\ 4" lift per 52" swap.:confused: :confused: :confused:
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    You will need crossover with 52's if you want to be able to steer when flexing. Plus the stock steering setup does not like moving the axle 2 inches further forward. And there is no way that I know of to use a 2wd box with a push-pull (4wd) steering linkage.
  3. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    It will be fine as long as you don't take the truck off road.
  4. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    Yes, you pretty much have to run crossover with 52's.... you'll have no steering control when flexed
  5. xtrmjoe
    xtrmjoe 1/2 ton status
    Aug 3, 2004
    330
    Boonville, CA
    With the 52's up front and any wheeling the linkage acts as a limiting strap and there is a lot of force applied to those parts, on top of haveing no way to turn the huge beast.
