x over ?
Discussion in 'OffRoad Design' started by hd-10, Feb 19, 2005.
  1. hd-10
    hd-10 1/2 ton status
    Jan 31, 2004
    188
    lemoore, ca
    hey steve on the dana 44 knuckle that has to be machined. i heard that it wold be a mirror image of the otherside. if thats true i should be able to use the old steering arm for a templete to drill out the pass side knuckle?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Yes it is a mirror image of the drivers side.
    But not only do you have to drill and tap the holes for bolts/studs, but the knuckle surface has to be milled flat for the new steering arm to sit correctly.
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    He's right, mill it flat, then drill and tap. You do have to set the location for the pattern. We have a couple of jigs that make all this easier since we do quite a few of them.
  4. onlychevy6
    onlychevy6 1/2 ton status
    Mar 29, 2003
    1,293
    Hockley, Texas
    i just got a set of knuckle to do the crossover steering set up. and they need to be machined (meaning both the passenger and Driver side) can you do this? or should i find a local source to get this done? i will be purchasing your crossover set up for my 78 blazer.
    thanks
    Jeff
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    The drivers side knuckle should be set to go if it is off a chevy. It should already have the holes and steering studs. The passenger side is the side that much be matchined, drilled, and tapped.
    Harley
  6. onlychevy6
    Mar 29, 2003
    1,293
    Hockley, Texas
    yeah, i was told that. however since it is off a 73 blazer i wanted to have them both freshened up so there is no issues. i have a 78 blazer and was not sure about this conversion. at least the how to and what is involved.
  7. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    To freshen up the driver side knuckle all you need to do is replace the ball joints and install new steering arm studs.
    Harley
  8. onlychevy6
    Mar 29, 2003
    1,293
    Hockley, Texas
    thanks for the info was not aware of that.
  9. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,069
    203
    Colorado
    ORD can do the machining of the passenger knuckle or you can have it done locally.
    Give Stephen a shout on Tuesday and he should be able to help you out then.
  10. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    We can machine them, it's typically $60 if you send a CLEAN knuckle with no balljoints.
