x-overs
Discussion in 'Audio' started by WakeBoard&4X4er, Feb 21, 2002.
  1. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    OK, I am looking for a 2-way passive x-over that roles off at about 120. Or a low pass coil in the same range. This is what I am doing with this stuff I am trying to run 2 4 subs with 2 8 speakers, however I have the subs running full range and would like to split the signal or adding a bass coil before the subs. Any have any think that will work???
    91 K5 and 73 Cobalt http://brettmcox.rockcrawler.com
  2. Prembird
    Prembird 1/2 ton status
    May 15, 2001
    811
    kc, mo.
    what type of subs and speakers are they... What brand, what ohm load, etc... Also fosgate use to make what was called a 6.6 coil but they no longer make it.. Are you trying to run them off the same amp?? What is your system setup like... Basically we need a little more info to tell you what you could do and with what parts...
    Prembird
    [​IMG] <font color=blue> If it aint</font color=blue><font color=red> LOUD </font color=red><font color=blue> Then turn it </font color=blue><font color=red> UP</font color=red> [​IMG]
  3. WakeBoard&4X4er
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
  4. Prembird
    May 15, 2001
    811
    kc, mo.
    well if all you want to do is make sure the subs are getting a low end signal then just go to the local radio shack and you can get x-overs there... They have them in 2 way, 3 way, and bass only setups... With the little info you have given i am guessing that is all you want to do...
    Prembird
  5. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    you might think about running some audio control components with a sub sonic blocker. sub sonics kill subs
    </font color=blue>
    <a target="_blank" href=http://blueknight.alloffroad.com>http://blueknight.alloffroad.com</a>
    "If First you don't succeed, Destroy all attempts you've tried"
  6. WakeBoard&4X4er
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    Hear is some info if any wants to know, If you use a bass coil it does not care if you put it on the - or + side of the spearker. So if you want to run 2 sets of speakers and you want one to be x-over with a coil, then you can ONLY run them bridged. If you want to run in seires, then you can no use inline xover.
