x
Discussion in 'The Garage' started by 2drtahoez71, Jan 22, 2004.
  1. 2drtahoez71
    2drtahoez71 Newbie
    Jan 22, 2004
    xxx
  2. dyeager535
    26,979
    Re: 14bolt SF 8 -6lug conversion
    Awfully new, but I think SF's from around '88-up can donate the axles you need. If search was looking, I'd be able to go back and look it up, I know the years were covered before. I don't believe spline count changed betwen '88 and 2000, at least.
    Is that a disk brake rear end? Again from my poor memory, depending on the drum size (if so equipped) the axleshafts are longer or shorter, but not the housing.
  3. dyeager535
    26,979
    Someone on here said the axle assemblies were different widths depending on some variables, but all I ever found in reference was that based on drum brake size, some axleshafts could be longer or shorter, but still interchanged.
    my 14SF post
    Theres more older info, but since search isn't working...
