Xfer case brace
Discussion in 'Parts & Trucks Wanted' started by Tweetysuarus, Jun 2, 2002.
  1. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Hi I have 76 GMC Jimmy 350/TH350-NP203.............lookin for the brace that runs from the Xfer case to the engine. Anbody got one in Sacramento Area or close by?
    Thanx, Bill C
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    If you can measure from the holes on the side of the 203 up to the 2nd hole up from the bottom on the passenger side bellhousing, I can check if one I have is long enough for you. /forums/images/icons/wink.gif
  3. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    Thanx, iwas lookin for something local around Sacramento area But if the price & shipping is right I just might consider.
  4. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    so this brace we are talking about here, along with the one that goes to the frame off the t-case would really help a bit?
    grant
  5. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    I'll do that this weekend cause I gotta get a tape measur & some other tools I need at the store Sat. morning,then I'll measure it and PM you. Also do you have the two big narly bolts that hold on that brace as well if not I can pick up some at the hardware store I think.
    Thanx,
    Bill C
  6. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    Yes it would ........ I would like to find one and replace mine before I go wheelin'
    Thanx,
    Bill C
  7. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    Hi, I think it's 31" from the last hole to the second one up on the bell housing.
    ______________________
    last^ hole
    The two holes are 3-3/8" center to center.
    Thanx,
    Bill C.
  8. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    what is wrong with yours?
    can it be fixed?
    grant
  9. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    Mine is missing!
  10. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    if i had one so is mine....
    but i would like one
    grant
  11. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    I guess I only have the "L" bracket on the x-case, not the rod.
    Sorry...
  12. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    Well how much do you want for one of them? If you are willing to part with one that is.Hmmmmmmmmm?
    Thanx,
    Bill C
  13. thatK30guy
    Jan 12, 2001
    32,076
    55
    Bill, I checked another tranny/t-case combo I have with the brace still bolted on and it's mounted to the lower bottom hole on the bellhousing.
    I measured from the outside of the bar on the bellhousing side to the first inside hole of the t-case side and it comes to around 29 3/4".
    Check your measurement again, but from the bottom hole on the bellhousing. /forums/images/icons/wink.gif
  14. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    Yes sir it be that measurement indeedy! So how much is the question for the brace and the shipping? be nice now please..........
    Thanx,
    Bill /forums/images/icons/smirk.gif
