xfer case fluid - ATF to gear oil?
Discussion in 'The Garage' started by ascuro, Sep 3, 2006.
  1. ascuro
    ascuro Registered Member
    Sep 19, 2005
    62
    SoCal
    I'm planning on switching my NP205 fluid from ATF to gear oil - how concerned should I be about cleaning out all the remaining ATF? Would a simply drain and fill be enough?
    I'm guessing there shouldn't be any problems with a little remaining ATF in the case, but better to ask and be sure :wink1:
  2. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    Does it really matter which one you use?
  3. yoshisv
    yoshisv 1/2 ton status
    Feb 19, 2006
    266
    Hartsville, Tennessee
    I thought NP205's are suppose to run gear oil anyway. I have always been told to run gear oil in cast iron cases and ATF in aluminum cases. I could be wrong though.
  4. ascuro
    Sep 19, 2005
    62
    SoCal
    Yeah, pretty sure they're supposed to be filled with gear oil - ATF isn't supposed to hurt though, but mostly I want to see if it'll fix the tiny amount of seepage I'm getting from the shift rail seals (I can't seem to find these sold seperately, only as part of a master rebuild kit). Since gear oil is a bit thicker, I'm assuming it should help.
  5. jamber2541
    jamber2541 1/2 ton status
    Apr 10, 2006
    424
    e.p. texas
    np205 uses gear oil, np203 uses motor oil, np208 and newer aluminum cases use ATF
  6. Chevy305
    Jan 23, 2006
    11,228
    485
    New Hampshire
    Wait how much fluid does say the NP208 take?
  7. 4by4bygod
    4by4bygod 1/2 ton status
    Nov 13, 2003
    3,859
    With My Tinfoil Hat
    Why do you want to change to gear oil? Don't get hung up on a " thicker oil means more protection" mindset..a higher viscosity lubricant doesn't equate to higher film strength, or the ability to absorb more heat.
    Tom
  8. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    FWIW, I looked into the factory spec'ed oil for my '91 crew (465/205 combo) and it was Dexron 2 ATF.
    I put gear oil both and found it to shift nicer, and a little quieter.
  9. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Mine took just over a gallon of ATF:D
    Ira
  10. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    5 quarts (as listed in the shop manual).
  11. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    wrong, to a point. The newer 205s ran ATF. ATF is thinner. If anyone is of the mind set that synthetic diff lubes and such will gain you power and mileage, then run ATF in the xfer case ;).
  12. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    I remember reading a post about this gear oil vs. ATF and it seemed that in the factory manuals the earlier 205 required gear oil and the later model ones required ATF. not necessarily because the internals are different in any way, because to my knowledge there not, but this probably related to gas mileage more than anything. I run gear oil in my 205 in blazer (wheeler rig) and ATF in my daily driver crew cab. Dont ask me why just figured I would try it out...:dunno:
  13. jamber2541
    Apr 10, 2006
    424
    e.p. texas
    would the difference be slip yoke =ATF, fixed yoke = gear oil
  14. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    Nope, my 88 has a fixed yoke 205 and runs ATF according to the owners manual. I would bet they skimped on luberication to gain fuel mileage.
  15. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    its not skimping on lubrication. and they didn't change internals so you could run ATF in an old one.
  16. RustyParts
    RustyParts 1/2 ton status
    May 26, 2005
    235
    Wyman, Kentucky
    If you use 80 - 90 gear lube in an aluminum gearcase you stand a good chance to crack the gearcase in cold weather because of hydraulic pressures generated by the gears compressing the cold lube.
