xfer support strut
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KRAZIE87K5, Jul 11, 2001.
  1. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    OK, I have this support strut (metal bar) that bolts from the xfer to the bell housing. Only problem is that the dual exhaust I have installed is in the way!
    I have a TH400/NP205. Do I really have to install this, or do I have a high chance of breaking the adapter? Keep in mind I have a 454 in this truck... If I do need it, does anyone know if a place to fabricate me one that might connect somewhere else?
    <font color=red> Check out my truck @ </font color=red>
    <A target="_blank" HREF=http://24.10.209.54/bigolk5.htm>http://24.10.209.54/bigolk5.htm</A> [​IMG]
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    You need to have it or else the transfer case/transmission interface will loosen up frequently. Just about any fab shop should be able to build you a new one - I had to do a little custom fabbing on mine after it snapped off the bolt holding it in the block.
    <font color=red>Cripplefight!!</font color=red>
    <A target="_blank" HREF=http://pugsley.alloffroad.com>http://pugsley.alloffroad.com</A> Updated finally[​IMG]
  3. 4xmac
    4xmac Registered Member
    May 1, 2000
    82
    Calif. Oceanside
    Yes you need the support strut. If the strut is not strong it will break.
    MAC
  4. 4xmac
    May 1, 2000
    82
    Calif. Oceanside
    MAC
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    That strut bar also acts as a support to brace the tranny too. Without it, you can expect sooner or later, with hard wheeling and playing, the tranny tail housing to crack and break. I have seen this several times on the 350's also. If I were you, I would put the strut bar back in after finding a way to cut out that short piece of exhaust and re-route it out of the way. At least with fixing this exhaust piece, it will be cheaper than replacing a th400 tranny later after it breaks (if it ever does). [​IMG]
    <font color=red>I m so we Todd did.
    I m sofa king we Todd did.</font color=red>
