XJ Shaft
Discussion in 'The Garage' started by THISISWEIRD, Apr 9, 2007.
  1. THISISWEIRD
    THISISWEIRD 1/2 ton status
    Mar 10, 2007
    165
    WV
    I've been reading here a bit about the XJ shaft.
    I've just replaced my steering box and thought I might as well switch over to the XJ shaft while it's down. The XJ shaft will allow me to lose the rag joint and will tighten up the slop, correct?
    I've got a 91' blazer, so what year XJ shaft do I need and where do I find it? Do I need to pull the column or can I do it all from inside the engine bay? Also, what's the level of difficulty. The steering box was pretty easy.
    Sorry with all the questions....I'm such a newb.
  2. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    Yep, when I got my XJ shaft, the column had to come out....
  3. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
  4. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    There is no need to pull the steering column for this mod. Check the thread that was posted for full details.
  5. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    PM chevyfumes and tell him UYB sent cha..
  6. AZ79K5Project
    Jan 15, 2006
    2,082
    Arizona
    Stir...Stir...Stir...
  7. THISISWEIRD
    Mar 10, 2007
    165
    WV
    Thanks guys. I pulled one off at the junkyard yesterday and I can't get it to compress. It must be the wrong year. I'll try to find another one this weekend.
    I've replaced the steering box and now the ball joint on the front drag link seems to be busted. I'm hearing a knock as I turn the wheel and all the grease seems to be coming out of the joint. Maybe as I was pulling off the steering pump, I busted the boot. Anyway...on to this project.
  8. THISISWEIRD
    Mar 10, 2007
    165
    WV
    Oh..so one more thing. The PO didn't do anything to the steering arm or drag link when he lifted the truck. I think I'll go ahead and do this now while I'm replacing the drag link to prevent premature wear. Which should I do....get a new steering arm, or an adjustable drag link to fix the improper angle? Where do I get it from?
  9. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    On my old 84 K5 with the 10 bolt front and 4" lift I Just used the new arm. Worked great for mine, and returned the steering to factory radius.
  10. AZ79K5Project
    Jan 15, 2006
    2,082
    Arizona
    The shaft is held by two plastic pins. I used a propane torch to heat up the shaft enough for the plastic pins to melt, If it is a two piece, it will compress. It's a safety thing in case of a front end collision.
  11. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    Look for the plastic pins like AZ79K5 said. If it doesn't have them you can still compress it but it takes a little elbow grease to do so.
    Rick
  12. THISISWEIRD
    Mar 10, 2007
    165
    WV
    I'm beating that thing to death and It will not compress. There are no pins...gotta be the wrong year. I'll get one to work this weekend. Either that or I'll break my back trying!
  13. AZ79K5Project
    Jan 15, 2006
    2,082
    Arizona
    Post a couple of picks of the shaft you are using.
  14. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    I found out that some of them were setup a little different. Worse case scenario you could try a hydraulic press I suppose. Look at the 2 red circles in the pic. this is where I drilled out the plastic inserts. These are located by where the 2 halves join together. The bottom pic should give you a better picture of where they are located.
    Rick
  15. THISISWEIRD
    Mar 10, 2007
    165
    WV
    I don't have the images. Believe me, I beat the damn thing to death...it's not moving. It had some platsic sleeve on the bottom section. I just thought it was similar. I'm sure there's one around here somewhere and I'll find the right one. But there are no pins, and it's not a 2 piece.
    I did find the correct one, but it's in bad shape. At least now, I really know what I'm looking for.
    Thanks for all of the info. You guys are good, especially for someone that lives in BFE.
  16. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
