XJ steering shaft...
Discussion in 'The Garage' started by wetbackZO, Feb 7, 2006.
  1. wetbackZO
    wetbackZO 1/2 ton status
    Jan 30, 2006
    113
    Las Cruces, NM
    which year XJ's steering shafts will work on our GM trucks?? I want to eliminate the rag joint on one of my trucks cause I'm putting a body lift...TIA!!
  2. wetbackZO
    Jan 30, 2006
    113
    Las Cruces, NM
    I can get one out of a 92 and a 96...will these work on my 79K10? Anyone?
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    It should I think Rene is using one from a 96 my is from an 89.
    Ira
  4. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    I think mine is from a '90...
    Rene
  5. sandawgk5
    Oct 28, 2003
    6,881
    Check my gallery there are pictures of the one I put on my rig in there. Compare them to what you got.
    Ira
  6. wetbackZO
    Jan 30, 2006
    113
    Las Cruces, NM
    thanks, I'll get both of the ones I mentioned above and see how it goes, happy days everyone!
  7. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    xj is what? cheroke?
  8. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    XJ is a POS...otherwise known as a Cherkokee. :D
    Rene
  9. josh86k10
    josh86k10 1/2 ton status
    Feb 13, 2005
    423
    Knoxville, TN
    Hey now...careful
  10. wetbackZO
    Jan 30, 2006
    113
    Las Cruces, NM
    xj's aren't that bad...it's just a preference thing...I guess.
  11. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    We had an '88 for 5 years...it's not 'preference' or brand loyalty speaking, it's personal experience.
    Rene
  12. bear76
    bear76 1/2 ton status
    Oct 16, 2005
    1,065
    here
    Are there any sites that show, or dose any one have any picutues of the modifacation to the steering colum side to make this work?
  13. sandawgk5
    Oct 28, 2003
    6,881
    If you look in this picture you can see where the clamp bolt protrudes into the Double D area.
    All you have to do is put the shaft in place and take a drill bit and clearance the steering column shaft to allow the clamp bolt to slide into place. Take care to not damage the threads on the other side. I chased the threads with the bolt after I did mine to ensure no problems. You really dont have to take that much off and could prolly use a file. A drill for me however took about 30 sec.:D
    Ira
  14. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Did you have to modify the shaft to make it work?
  15. sandawgk5
    Oct 28, 2003
    6,881
    I did not change anything on the XJ shaft. I only clearanced the steering column shaft.
    Ira
  16. SUPER'BURB
    SUPER'BURB 1/2 ton status
    Jan 9, 2005
    929
    Mountain House, Ca.
    No kiddin:o
    Although I never drive it anymore, I am puttin a bunch of Chevy stuff under it and doin an exo to make it last. My burb will be the tow/camping/recovery vehicle.
  17. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Anyone with a 70's gearbox with the smaller input shaft done anything simmilar ?
    I have 70's box and ragjoints , and 80's box and ragjoints . The 80's are larger in diameter at the shaft on the box .
  18. wetbackZO
    Jan 30, 2006
    113
    Las Cruces, NM
    damn...I thought the XJ shaft was just a bolt on, as soon as I get to it we'll see how it goes. If it don't fit, I got a chop saw and a welder to make it fit:haha:
  19. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    my parts for my next one is from a wrecked 98 durango lol
    also to any xj fans I discovered the durango box 98-99 will bolt up in place of a factory xj steering box...much beefier
  20. wetbackZO
    Jan 30, 2006
    113
    Las Cruces, NM
    anyone got pix of the xj shaft installed on your rigs???:D
