Xtreme 4x4 X4270H Cam
Discussion in 'The Garage' started by littleryno32, Jun 27, 2006.
  1. littleryno32
    littleryno32 Registered Member
    Jun 27, 2006
    27
    Willis TX
    Is anybody using this cam in a sbc looking to build new engine wondering what to use? Any help would be great. Thanks
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,996
    134
    It all depends on what size sbc, what heads you are using, and what the vehicle will be used for. If it is on a 350 and will be used in a truck for good all around power, that is probably a decent choice.
  3. littleryno32
    Jun 27, 2006
    27
    Willis TX
    1980 blazer 350 sb
  4. littleryno32
    Jun 27, 2006
    27
    Willis TX
    Stock heads
  5. 1977k5
    May 26, 2003
    9,996
    134
    Go for it :waytogo:
  6. yoshisv
    yoshisv 1/2 ton status
    Feb 19, 2006
    266
    Hartsville, Tennessee
    Im using a XE262 on a TBI350 with bumped compression and stock heads. It has great off idle torque and throttle response. Also has a noticeable idle.
  7. littlejimmythatcould
    littlejimmythatcould 1/2 ton status
    Feb 6, 2006
    797
    Clovis, NM
    I'm using the 262H-11 and it's a pretty good cam with a steep power band, I like it, and hope when I move up in axle gears it will help put me higher up in it's power band. The advertised powerband on it is 1300-5600 but it never goes above 3600 rpm unless I was to totally wind out the motor. When it becomes a 'trail only' rig I will probably move up to the cam that your looking at. It also has a pretty noticable idle. If you get that cam let me know how it works out for ya.
  8. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    I'm running this cam in my 56. My engine is a 383 with almost 10:1 compression and aluminum heads. The idle is rough as would be expected with this grind, but not so bad that the truck isn't streetable. The engine pulls strong but I haven't had it on a dyno yet for a fine tune and power check. I'm happy with the cam for now, but will probably go to a milder grind sometime down the road. If I'm not happy with something milder, then I can always put this one back in.
  9. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    should be a good strong cam.... do you want that much cam?
    I went with Xtreme 4x4 X4260HR
    that one is a hyd roller.. but I wanted power from ide and up.... I like it so far.. havent got the truck out yet as wife is expecting in 2.5 weeks :crazy:
  10. littleryno32
    Jun 27, 2006
    27
    Willis TX
    Thanks for the info !!! Just found out my block is 60 over with headers. Still looking for heads my heads didnt match
  11. littleryno32
    Jun 27, 2006
    27
    Willis TX
    Does anybody have vac. problems
  12. Smitty
    Sep 1, 2000
    999
    Crestview, FL
    I was worried about the vacuum. I went ahead and installed a hydroboost brake system before I put the engine in the truck. I also run a vacuum gauge and it reads around 17" at idle, so no problems there.
  13. littleryno32
    Jun 27, 2006
    27
    Willis TX
    what size stall do you run?
  14. yoshisv
    Feb 19, 2006
    266
    Mine does not have any with the XE262
  15. littleryno32
    Jun 27, 2006
    27
    Willis TX
    im thinking i may just use the xe626
  16. littleryno32
    Jun 27, 2006
    27
    Willis TX
    opps ex262
  17. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    I've been running a Rhodes Hydra-solid cam for over a year and have been real happy with it.
    Good low, mid and top end power. Pulls 19" of vaccume at idle.
