Xtreme rock machines - I know repost
Discussion in 'The Garage' started by bigburban383, Feb 26, 2004.
  1. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    What did you do for mods? I cut the front springs and loosend the ladder bar screws. Thinking about shaving the rear axle. My roomates got one, we are just screwing around modding them.
  2. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    dude, i've spent too much time on those things..
    see what i've been doing.
    xtreme rock machines
  3. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Ive done a bunch to em as well. Cut that trianglation off the frame, no shocks, and cut tires. RockBuggy /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif
  4. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    where do you get those?
  5. BOWTIE
    Dec 28, 2000
    2,018
    wallyworld has them for 6 and change.
  6. BOWTIE
    Dec 28, 2000
    2,018
    i noticed on some of your pics that you have the control arms still in the stock position. take one from each side and flip it. it helps with the movement onf the axles.
  7. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    what the hell is wallyworld? thats the place Clark Griswold takes the family in "National Lampoons Vaction"
  8. BOWTIE
    Dec 28, 2000
    2,018
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    sorry about that..
    wallyworld = walmart
  9. bigburban383
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Dude, you are awsome /forums/images/graemlins/bow.gif The video of the big rock course is sweet Rock Course
    This is facking sweet too /forums/images/graemlins/waytogo.gif
    Man, now im going to have to go back to Walmart /forums/images/graemlins/1zhelp.gif
  10. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    those things are kick ass... now if i can only find a walmart.... Never been to one before...
  11. bigburban383
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    sorry about that..
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  12. bigburban383
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Do you just cut off the springs, then relocate the shocks so that it sits lower? Because mine sure as heck cant crawl over something taller than it.
  13. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    OK bowtie, you busted a belt too, did you find a replacement or place to get them?
    And how did you get those tubes over the belt in the first place?
    I've got a few of these and so does my son, and we were having a pull off on the table, well he won after he managed to get my belt to break turning the buggy into a freaking FWD honda thingy. /forums/images/graemlins/histerical.gif
    I'm thinking of griding the diffs down and putting the limiting straps on the front axles since they droop too far. I was also looking at a way to make the shocks droop more so I migh not need the straps, but man are these things fun! /forums/images/graemlins/peace.gif
  14. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif You either live in a hole or make $500,000 a year! /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  15. BOWTIE
    Dec 28, 2000
    2,018
    for the front i removed the springs but left the shock and just relocated to where you see them in the picture. i don't like the way it looks with out the shocks so i left them. the rears are stock and just relocated.
    not sure if you noticed the limiting type straps the i used, but that keeps the axle close to the frame and allows the axle to pivot up and down. if you do any of what i did you will need to clearance /forums/images/graemlins/hack.gif the frame or the shocks will hit and bind up travel.
    i told you way too much time. but they are cool as heck /forums/images/graemlins/peace.gif
  16. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Are these just a turn on/off sorta thing? /forums/images/graemlins/1zhelp.gif
  17. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    What did you use for lockers? I used a bic pen tube but its a bit too tight
  18. BOWTIE
    Dec 28, 2000
    2,018
    belts can be changed when you remove the "lug nut" from the axle. real easy and replacement belts came from a donor truck.
    ok, the tubes were from a pen that i had here at the house. i've seen some where they used straws, but that binds the belt too much and causes it to break. my rear tube is about an inch and the rear is 3/4.
    oh, add the washers to the tires that helps keep the axles down and they look like beadlocks. /forums/images/graemlins/waytogo.gif
  19. BOWTIE
    Dec 28, 2000
    2,018
    yes kinda like the old stompers.. point and shoot.
    daleearnhardt01 - i used a bic "wide body" pen.
  20. RustBuket
    Feb 21, 2003
    1,618
    Gotcha, I've never seen em b4.
