Y-pipe hitting passenger spring
Discussion in 'The Garage' started by Sample, Aug 27, 2003.
  1. Sample
    Sample 1/2 ton status
    Oct 15, 2002
    536
    Apache Junction, AZ
    I just put in a used y-pipe, as mine was non-existant. I fire it up and drove around the block. As soon as I turn to th right, even a slight amount, I hear a grinding rotational noise. I didn't think it was the pipe at first so I repacked the front wheel bearings, hit all or the zerks with the grease gun, checked the brake pads for funny wear. Nothing, I am assuming it is the pipe, but why does it sound like a grind instead of a bang? The pipe is actually resting against the spring.
    thanks, Chris
    83 K5
    350/400/203
  2. Sample
    Oct 15, 2002
    536
    Apache Junction, AZ
    Where does the passenger side of your y-pipes run?
