Ya know what sucks....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muddin4fun, Jul 24, 2001.
  1. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    When you find out you have a messed up hub BEFORE you have a chance to wheel it! WTF! Nick was following me and said that he saw the drivers side hub slowly spinning.
    I shall enact my warrentee!
    Don't mind me, I'm just venting...
    I've got a mind like a . . . a . . . what's that thing called?
    <a target="_blank" href=http://www.geocities.com/muddin4fun79blazer/>http://www.geocities.com/muddin4fun79blazer/</a>
  2. J.R.
    J.R. Guest
    the joy of owning an older truck!! LOL
    BIG BLOCK MAN
    "MORE POWER"!!
  3. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>This is normal. When in 2WD with the hubs unlocked, the front driveshaft (along with the R&amp;P and axleshafts) does spin slightly from the oil being slug around in the transfer case. I can see my front driveshaft while driving (very well too, dont ask [​IMG]) and it does turn a little. If the front axles are spining slowly, dont worry about it, your hubs are not damaged. If anything your moving the internals of the axle around in the oil which is a good thing. </font color=blue>
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    but she said her hub was turning not the driveline and that cant be a good thing
    77blazer see it at<a target="_blank" href=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</a>
  5. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    I haven't run into this, but it seems as thought the hub locking unit shouldn't turn unless its locked. Sounds like the rotory motion of the rotor is giving off a little grabbage on the locking unit. Maybe you have it installed incorrectly, and it wont let the rotor spin freely, thus the rotor is trying to take it for a spin. But if you dont hear any grinding and such and it locks when when locked I'd not worry too much, but hey if its under warranty, why not. **shrug**
    Beer!!!! Its not just for breakfast anymore!!.[​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  6. Grim-Reaper
    7,385
    Atlanta
    NP203 that are converted to part time do this pretty common. The output shaft from the reduction box is the shaft that the upper chain gear rides on in the chain section of the box. As the roller bearings spin some of that is transfered to the chaiin gear and the drive shaft slowly spins as you go down the road.
    As it was pointed out in the other reply it's normal on 203 cases. Spin the front drive shaft by hand and if both axle shafts spin you have nothing to worry about.
    It's not my damn planet monkey boy!
    <a target="_blank" href=http://communities.msn.com/OffroadK5s>communities.msn.com/OffroadK5s</a>
    Grim-Reaper
  7. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    but she said the hub was turning not the drive shaft
  8. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    The hubs are under warrentee and are easy to put in, so why not! LOL! That one gave me some trouble when I was installing it. It didn't want to go on there. Warn will warentee them for me, so if it fixes it, great, if it does the same thing.....I dunno *shrug*.
    But I'll check the axle shafts just to make sure.
    Thanks guys!
  9. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Are all Warn hubs "fused"? When I did my ball joints I removed the hubs and both sides had an internal ring with ears on them that we're both broken to shreds. They were made of black plastic. I've seen some stuff about fuses that will break b4 any axle or diff parts break, but I havent done anything to break them I don't think.
    "My blazer may be slow, but it goes faster at higher speeds"
    <a target="_blank" href=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</a>
    Jim
