Ya think I need a new Tcase?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Brian85gmc, Sep 4, 2002.
  1. Brian85gmc
    Brian85gmc Registered Member
    Sep 4, 2002
    37
    Canton, MI USA
    Hey there. This is my first post on these boards and it's a good one.
    with the hubs locked, if I put it in 4 high I get nothing. If I put it in 4 lo, it nocks the shift lever right back out.
    What do you guys think could be wrong? I'm really hoping I don't have to replace this thing.
    Thanks alot!!
  2. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    Does it work in 2WD? You can drop the rear driveshaft and pull the backhalf of the case to check it out inside. could be a shift fork problem.
  3. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    It could be just the shift linkage. You could try moving the lever inbetween where the ranges are indicated on the shifter. Try going betwee the 4H and N marks and see if you can find 4HI. If you can't move the shifter far enough back to engage 4LO that could be why it's jumping out.
  4. Brian85gmc
    Sep 4, 2002
    37
    Canton, MI USA
    yeah, it works in 2 wheel.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It could be low on fluid or the shifter could be out of adjustment.
  6. Brian85gmc
    Sep 4, 2002
    37
    Canton, MI USA
    I sure hope thats all it is
    Just gotta get it working before winter.
    Plus, I want to show it to my MyBigBronco.com friends titled "My straight front axle swap". I have'nt told them I bought it yet! /forums/images/icons/wink.gif
    Thanks for the thoughts, I'll let ya know how it goes.
  7. Grim-Reaper
    7,385
    Atlanta
    Damn another one of these Yankees /forums/images/icons/smile.gif
    I was born in Detroit.
    Nothing worng ith the 10 bolt if your running 33's and under and mostly street. You start hammering it off road and then you might start having problems. With you being in the rust belt 14 bolts and 12 bolts are a dime a dozen. If the 10 bolt gives up save your money and swap the axle. You can probably find a 14 with a Detroit for around $200. Might even find a matching front axle out of a 3/4 ton. Then your ready for 36's. If you have ambitions of bigger than 36's start looking for a front D60. Find a old K30 rust bucket plow truck for $500 and then your set with the strongest parts.
