YAHOOO!!!! Just recieved my Rough Ccountry lift.. any tips???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90idahoblazer, Oct 5, 2001.
  1. 90idahoblazer
    90idahoblazer 1/2 ton status
    Jun 24, 2001
    183
    Idaho
    Hey, just recieved my 2" lift today. Any pointers before I get started. Any would be greatly appreciated.
    Thanks in advance
    <P ID="edit"><FONT class="small">Edited by 90idahoblazer on 10/06/01 09:06 AM.</FONT></P>
  2. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    Re: YAHOOO!!!! Just recieved my rough country lift
    hey, congrats &amp; keep us posted!!!
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>link to k5's</a>
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
  4. EDdaTREE
    EDdaTREE 1/2 ton status
    Feb 18, 2000
    1,253
    Austintown, OHIO
    The lift on the '76 I bought 5 years ago has Rough Country shocks...it's a California Blazer so it could be ANCIENT!! The springs still flex and are strong, the shocks are good for the most part. I took my beast off-road and pulled people all over to get them un-stuck, took it down trails that were not to be believed, and just basically ROMPED!!!
    9/11/01..Never forget...Never forgive
  5. 90idahoblazer
    Jun 24, 2001
    183
    Idaho
    Thanks for the vote of confidence.....It sounds like I went with the right company....They have great service...I ordered it Tuesday and recieved it Friday. I hope the product is as good as the service....
  6. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    As for any tips just one comes to mind use some penetrating oil for the u-bolts and the spring bushing bolts. When I put mine on I put anti seize on the bolts and the bushing.
    Eric
    <a target="_blank" href=http://cethern.tripod.com/erics-home-page-and-other-stuff/>http://cethern.tripod.com/erics-home-page-and-other-stuff/</a>
    AMSOIL Dealer # 529948
    Cethern@interfold.com
  7. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I have been quite pleased with my RC 4" lift. One thing, after you have it all finished, drive it around the block a couple of times and then re-tighten all the bolts. Then, after about 50-100 miles, do it again. I even re-tighten mine before and after each wheeling trip.
    You would be amazed how much things loosen after settling even on a drive around the block!
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  8. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Take some pictures pleaze! I'd like to see what a 2" looks like, everybody seems to have 4".
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
  9. 90idahoblazer
    Jun 24, 2001
    183
    Idaho
    If I can get the old ones off....I will send you some pics....thanks for the torch tip by the way,...
  10. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    make sure you got an exstiguisher handy, and remember those springs are close to the gas tank! (we did the torch method too, and it turned out with no problems)
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Don't waste your time trying to remove those U-bolts, just cut them.
    Why 2"?
    I once put a small add-a-leaf/block combo on my truck for a 4" lift. Now I have a 4" Rancho. I am going 8" now, plus a 1" body. I hope my truck doesn't grow again after that, it's a shortbox and that's about as big as I want it!!
    Tim
  12. 90idahoblazer
    Jun 24, 2001
    183
    Idaho
    Well I like the gas milage with the stock tires almost 20 mpg....also I had blocks on the back which are much less stable. I do alot of hunting and fishing ...not rock crawling or muddin.....Also I have not had one lick of problems with my tranny or axels from running monster tires.....So I guess this poor old GI is saving money in the long run by not breaking things.....unless I start tearing into them...lol....and last but not least it would have cost me more to put it back to stock height than a 2" lift from rough country.....2'' still looks ok with 31'' tires.
  13. Overdrive
    Overdrive Registered Member
    Feb 28, 2000
    93
    Gilbert, Arizona
    Cool! I will be ordering my 2" front springs from RC in about 2 weeks. Just take your time. When I put the 2" rear springs on a couple of weeks ago I made sure to do one at a time, not both ( disconnected form axle) helped a bunch. Make sure you release your parking brake to give you some slack in the cable. Make sure you have either a sturdy piece of pipe or a crow bar to help guide (push) the rear part of the spring/shackle into its craddle so you can get the bolt in. I am liking my new 2" on the 89' Suburban better than the 4" on my (now sold) 77' K5. There are a lot less things to change, watch, replace, etc... with a 2".
    Good Luck!
    Overdrive
  14. 90idahoblazer
    Jun 24, 2001
    183
    Idaho
    I have nothing but good things to say about this company......They have been so easy to work with....I was missing some hardware and they overnighted them to me. My 2" lift is so smoothe...rides and looks so much better...and the Heckethorne shocks they sent with the kit are awesome.....If nothing else their customer service is worth dealing with them...these guys bend over backwards to make sure you are happy.....If you order from them ...Talk to Jeff he will treat you right.......
  15. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Lots of PB nutblaster! And let it soak overnight. And get the steering arm real good too!
    One thing I found was the center bolt on the front springs were too long and I had to grind them down some so the plates that the u-bolts go thru could sit nice and even. Other than that, my lift went real smooth!
    <font color=blue>Women should put pictures of missing men on beer cans...</font color=blue>
    Website link is in my profile [​IMG]
  16. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    i ave the same lft- my 2 tips are
    1- do the rear 1st, its less of a hassle than the front an dles frustrating
    2- have a can of pb blaster handy
    <font color=red>K5: Because size DOES matter</font color=red>
    85 K5 4IN LIFT 35 GOOD YEAR WRANGLER MT/R, AMERICAN RACING WHEELS
  17. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I forgot to mention the #1 tip that would have helped me on my spring swap:
    DON'T TIGHTEN THE DAMN SPRINGS UNTIL YOU HAVE THE AXLE HANGING FROM THEM!!!
    Tim
