yakima roof rack
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cp87jimmy, Jan 9, 2001.
  1. cp87jimmy
    cp87jimmy Registered Member
    99
    Frisco,TX
    Hello to all, I haven't posted in quite sometime. I've been lurking in the shadows though. Anyhooo, I need suggestions on mounting the rack to my Jimmy without already having provisions for such a rack. It looks very simple on Steve's truck with the soft top. My top is the stock hard top without any type of luggage rails. Is there a insert or something that will except a bolt without going through the topper? Something I can bolt the "T" brackets to? Any and all suggestions appreciated.
    Anybody got any ideas?
    GO STARS !!!!!
  2. CK5
    May 19, 1999
    21,627
    704
    CO
    I believe you can mount the towers to your side window trim, they also sell a generic kind of mount that is used to bolt on top of shells, I would just give them a call, I believe I put their 1-800 number at the bottom of the review.
    Steve
    1990 K5 with stuff
  3. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    ok i install yakima racks at where i work and here are the 2 options, either way there will be drilling to the topper. the 1st way is to buy gutter racks, 1 bar will slide into the gutters on your window, then for the rear part gutters are "made" w/ a kit. they are 5inch wide gutters that are drilled into the hard top EVENLY and then the gutter bars slide into the new gutters
    option 2 is all on the hard top, and that is the sliding rails are drilled into the hard top and bars are put on there.
    but dont be worrited, the drilling doesnt cause leaking because there is a sealent put on the nuts.
    the 1st way has more space between the bars and arent adjustable but the 2nd way are adjustable but not as much space between the bars.
    i like the 1st way.
    Confederate's w/ K5's!
    '85 K5: BIG BAD AND MEAN
    K5: Because size DOES matter
  4. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I bought a used Yakima rack for my Blazer. I put part on the roof and used the rain gutters. The other part I drilled through the topper(hated doing it). I put a little silicone around the holes and no leaks. I carry 6 bmx bikes on the roof as well as well as a home made basket full of stuff for camping etc. no problems. They're a must have item.
    creepin' and crawlin'
    Jim
  5. cp87jimmy
    99
    Frisco,TX
    jimmyjack, did you drill completely through the topper? is it double walled? i would like to insert some kind of anchor in the topper if possible. thanks
    GO STARS !!!!!
  6. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    It was my intention to go thru the thicker part of the shell but I didnt follow thru on my plan. I put some big washers on the inside if the topper just to spread the surface area(kind of) and its held up pretty well. Like I said I carry 6 BMX bikes up there. The nuts they give you are nylon threaded so they won't back off and with a little dab of silicone it's leak proof. Good luck.
    Jim
