Yanking the motor...
Discussion in 'The Garage' started by dremu, Oct 13, 2006.
  1. dremu
    Feb 27, 2000
    15,967
    459
    East of San Francisco
    Since the motor seems to think it's a Detroit, i.e. No-Spin :haha: See http://coloradok5.com/forums/showthread.php?t=187193
    I figger it's a nice winter project to pull the thing, in preparation of having enough money to rebuild it or get a crate (still toying with the options.) The tranny has been running okay but leaks like a sieve, so it sounds like a good time to deal with that mess.
    Truck is a '74 C30 sixpack, 454/TH400. I think I'll pull the engine and tranny as one, which means removing the hood (it's misaligned anyway), and the radiator and batteries and such up front, no big deal.
    I have a nice cherry picker, like 2-ton with the arm at the shortest, and one of those engine balancer things ... uhh... like
    http://www.partsamerica.com/ProductDetail.aspx?categorycode=3396&mfrcode=PBI&mfrpartnumber=647525
    one of those. Should have enough chain to hook to the engine and tranny.
    Anything else I'd need, tool-wise? For the removal, that is -- rebuilding would be left to a pro :D
    Also, quick check-off of stuff to disconnect:
    Driveshaft, of course :D
    Fuel lines at the fuel pump
    Tranny cooler lines at both ends
    Motor and transmission mounts, tranny crossmember
    Shift linkage
    Minor electrical stuff, like the coolant sensor on the driver's side
    Should prolly pull the dizzy BEFORE the engine comes out, so I don't crack the cap or anything, yeah?
    Any other gotchas I should be aware of? Should I forego the engine-and-tranny-as-one idea and pull the engine up, drop the tranny down? I *really* don't want to pull the carpet and the floor hump on this truck ... or do the 2WD's even have the removable hump?
    -- A
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    You can pull just the engine and leave the transmission in the truck if you have no trans work to do. Place a jack under the trans pan to remove the engine, then use some heavy gauge wire to support the transmission by putting it through one of the bolt holes and tieing it to the brake booster or something else solid. Otherwise, I would pull them as one unit. Removing the fan will give you some extra room too. Chains connected to the engine. The crossmember may be able to stay. Lift the engine off the mounts, then lift the tailshaft to get the bolt out of the crossmember and everything should move forward.
    Speedo cable and kick down wire.
    There may be a ground strap, possibly from the rear of the passenger head to the firewall.
    Have fun with the exhaust.
  3. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    remove exhaust off manifolds, ground wire on pass. rear of block, sending units(oil pressure, temp...), pull cap off distibutor atleast, Might pull the fan off so its less to catch and cut yourself on also, drain the tranny of its fluid!!! going to loose coolant out of the block also, When pulling it have a buddy to help, Watch for the AC "housing" on the firewall on the pass. side. the engine and tranny get really close when pulling it out and can break it easily. Speedo cable.
    Pretty easy to notice if you forgot something while pulling. Just take your time.
  4. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    I pulled the 454 out of my old '86 3+3 without touching the dizzy, but I also yanked the radiator.
  5. dremu
    Feb 27, 2000
    15,967
    459
    Ah yes, speedo cable ... exhaust... ground straps, check.
    Kickdown wire is electric, being a TH400. Check. I think I'm gonna pull the tranny regardless, get this truck done right, maybe it'll make it to BlazerBash 2008 :haha:
    The tranny will be drained ... the engine has already drained itself of coolant :mad: and the fan is already off as part of my diagnosis of its no-spin attribute, so that's all good.
    -- A
  6. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    removing the entire radiator support gives you tons of room to work. Then you don't have to go real high with the engine to get it out. Don't forget the power steering hoses.
  7. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    oh and the hood.
  8. divorced
    Jul 20, 2004
    5,115
    I usually just unbolt the pump from the motor and set it to the side so I don't have to worry about refilling it again.
