Yay or Nay--center caps on h2's---So what if I'm bored
Discussion in 'The Garage' started by SCOOBYDANNN, Jan 10, 2007.
  1. Yay
    6 vote(s)
    16.7%
  2. Nay
    19 vote(s)
    52.8%
  3. I like chocolate
    11 vote(s)
    30.6%
  1. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
  2. DaPlumber
    DaPlumber 1/2 ton status
    Apr 4, 2003
    212
    Holland Oh.
    Im not real hip on the factory center cap's for the H2.. If It was me I would run with out them.. Or run one's like I do!!!
  3. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    I really like the way yours looks, but I'm not real keen on spending $40 on new lug nuts and then whatever the plastic ones cost and then finding the caps themselves.
  4. Craig Artzner
    Craig Artzner 3/4 ton status GMOTM Winner
    Dec 16, 2006
    6,843
    Northeast Ohio
    I like the way DaPlumber's looks. I'd run caps like his or none at all, which also looks good.
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    and unfortunately for you, that also means new studs all around as those lugnuts are metric.
  6. DaPlumber
    Apr 4, 2003
    212
    Holland Oh.
    No they are NOT metric!!!!
  7. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    someone has come up with externally threaded std lugnuts? :ears:
  8. DaPlumber
    Apr 4, 2003
    212
    Holland Oh.
    You can find them on Ebay....
  9. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    dorman offers them for conversions. std threads for the stock lug nuts and then the metric outer for the plastic caps.
  10. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    The factory lug nuts that came with my H2 rims are Metric.
    ...........Thank fully the center caps are not Metric though :p:
  11. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    I voted "I like Chocolate" because you didn't have "DaPlumbers or nekkid":D
  12. k204dr
    k204dr 1/2 ton status
    Aug 27, 2004
    463
    TN
    so anyone have a part # for the "conversion" Nuts? or a metric stud to fit a front D60? i've got the latemodel studs in the rear, and I just run the black plastic caps over the lugnuts. want to do the same in the front.
  13. DaPlumber
    Apr 4, 2003
    212
    Holland Oh.
    So you need some help with your home work?? Look on ebay for lugnuts!!! eBay item:CHEVY TRUCK 1965-87 LUG NUTS 8 LUG 9/16 GMC WHEELS 32 (#180073591709) Ok, I looked it up for ya...
  14. k204dr
    Aug 27, 2004
    463
    TN
    yeah I'm stupid, thanks. I tried looking them up and coudln't find anything under lugnuts. for some reason didn't think of trying the two words separately!
  15. K20Sub
    K20Sub Newbie
    Jan 13, 2003
    Vancouver, BC
    Scoobydannn,
    I have to say I really ike the look of those black rings that you used as caps. What did you use to make them and hold them on? Probably less likely to collect water etc than the modded GM caps.
    I have h2 rims sitting in my basement that are just itching to get on my '91v3500. Will probably have to wait for a small lift to go on first so I can clear 35's. Need to keep this truck city-friendly. :)
    Thanks,
    K20Sub
  16. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    daplumber's or none at all
  17. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I don't have center caps on my H2's and like them that way. Just one more thing to rub off. Now, if I didn't wheel it, I would get the center caps like DaPlumber's.
  18. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    They just snap into place like the cheapie hub caps you see.
  19. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    I like Da Plumber's setup too. When I had my 95 K2500 WT I replaced the stock steelies for rockcrawlers, and threw the stock caps, lugnuts, and lugnut covers in a bag and put them in storage. Pretty sure I still have em. I guess it's good I'm a packrat. H2's are everywhere down here, I'm going to have to grab a set.
