Year/make/model of truck with 1350 CVs??
Discussion in 'The Garage' started by b454rat, May 11, 2006.
  1. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    I remember reading somewhere that Ford trucks had 1350 CVs in them, but can't remember what years, models, rating, etc. Any other truck that would have one??
  2. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,603
    556
    Wasilla AK,
    Cucv????
  3. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    try 99-03 superduty (f250, f350) 4x4's, I know they have the 1350 cv's.
  4. MEK5
    MEK5 1/2 ton status
    Jan 21, 2006
    244
    Maine
    The Ford F250/350s 99-up have the 1350 CV front shafts that are pretty long,bought this one off ebay for just under a hundred.It measures about 55" flange to center of joint,will make a great rear Blazer shaft shortened and balanced slip end hooked to a 14bolt.
  5. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Good find and price.
  6. b454rat
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Hmm, will have to remember that...Thanks!!
  7. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    will the flange on this bolt right up to a standard 205 front flange and a high angle drivelines 205 rear flange???
  8. yellowK20
    Dec 26, 2002
    7,603
    556
    Wasilla AK,
    oops I'm about a dip **** guess I should have read a bit better CV shaft :doah: :doah: :doah: :doah:
  9. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    I am pretty sure that is what Jess uses for his 1-ton CVs, so yes they will bolt to his drive flanges.
  10. 79k20350
    Nov 22, 2004
    7,757
    Ct
    cool, thanks:D
  11. MEK5
    MEK5 1/2 ton status
    Jan 21, 2006
    244
    Maine
    You can use a 30/32 spline flat flange 205 yoke by machining the pilot OD down some,the Spicer 1350 CVs come with a couple different size pilot bores.
    The factory Ford ones have the larger bore pilots,I micd mine and came up with 2.672 but dont quote me on that # because I didnt clean it up real well before measuring.
    I have a Hi Angle flange/e-brake kit and the pilot is 2" so I would say they use the smaller pilot flange mostly.
    To use the Ford shaft on the rear of a 205 just take a flange yoke from a 208/241 front output and machine the pilot,drill out the threads and change the seal size.
    This will work on the front to if you have a 32spline front output in your 205,I have done this several times and have the correct seal #s
    This picture shows a converted yoke.......I think
  12. 79k20350
    Nov 22, 2004
    7,757
    Ct
    hmm...interesting few questions...
    For the rear...
    If the ford pilot is bigger than why the need to machince the one on the flange..or am i misunderstanding something?
    Why the need to drill the threads out of the yoke? is the cv threaded?
    For the front...
    If your 205 already has a flange would that just take the same machining of the pilot?
    Now by pilot i assume you mean the ring on the flange that centers the shaft?
    Thanks alot!:bow:
  13. MEK5
    MEK5 1/2 ton status
    Jan 21, 2006
    244
    Maine
    The pilot on the GM factory CV flange is just under a 1/2" larger than the Ford 1350 CV flange.Out of the 2 Spicer 1350 CV flanges avaliable the Ford factory shaft has the bigger one but still smaller than a GM flange yoke has:ooo:
    The 1350 flange is threaded,that is why you would drill the threads out of the 32spline yoke if you were using it on the rear.
    In the front you could drill the threads out of the CV flange instead of the yoke.
    Yes,pilot is the centering ring:thumb:
  14. 79k20350
    Nov 22, 2004
    7,757
    Ct
    cool thanks alot...i got a buddy that works at a machine shop so that should help alot. one last question, if you have a 205 w/ a flange already you dont need a 208/241 flange correct, i can just machine the one i have?
  15. MEK5
    MEK5 1/2 ton status
    Jan 21, 2006
    244
    Maine
    Yup,If your talking about the front output.
  16. 79k20350
    Nov 22, 2004
    7,757
    Ct
    Yup, thats what i meant. Thanks again man!:D cheap driveshafts for me...!
  17. MEK5
    MEK5 1/2 ton status
    Jan 21, 2006
    244
    Maine
    After reading this again I just want to add that the Ford shaft that I bought is not good for a front driveshaft because it has a 3 1/2" diameter tube and will cause clearance problems most likely.
  18. b454rat
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    No way that you can retube it for the front?? I don't really have the $500 for a 1350 CV shaft for the front of my truck. Once I get the lift/trans/t-case stuff figured out, I dont think I will need a CV in the rear. I will have to get some pics, but my buddy is running a 95 Ram RCSB with HP60/Sterling combo, IIRC 15" of lift on 44s with a stock rear shaft. Since I will be close to half that lift, I should be OK.
  19. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i think im going to buy one, itll be ncie to have once i gte my doubler finished
  20. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i just picked up a brand new f250 shaft for $140 shipped :) via ebay
