years on dana 60
Discussion in 'The Garage' started by neverendingproject, Apr 3, 2007.
  1. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    For front axle applications, what years did they come in? And is a dana 60 from 70 pickup worth anything? Is it like the newer ones? (73-87)
  2. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    open knuckle d60's started in 77' or 78' until 91' in V3500's
    Older than 77' would be a closed knuckle and they aren't worth as much and aren't as strong.
  3. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    It looks open to me????
    He says its out of a 70 truck but maybe he meant 70's?
  4. mo
    mo 1/2 ton status
    Jun 29, 2004
    542
    Folsom, CA
  5. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    [FONT=Arial, Helvetica, sans-serif]GM [/FONT]
    [FONT=Arial, Helvetica, sans-serif]1977-87 K30 1 ton 4wd[/FONT]
    [FONT=Arial, Helvetica, sans-serif]1984-88 CUCV[/FONT]
    [FONT=Arial, Helvetica, sans-serif]1988-91.5 V30 [/FONT]
    [FONT=Arial, Helvetica, sans-serif]All GM / Chevy versions were passenger side differential, regular rotation (low pinion) gears, disc brakes, 35 spline inners, 30 spline outers, internal style hubs, and kingpin knuckles. [/FONT]
    http://www.pirate4x4.com/tech/billavista/60_front/index.html d60 bible
  6. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    Yeah, Ive read all that stuff already, but I need to know if its open knuckle then is everything good to go?
  7. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
  8. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    The axle in that pic isn't a 60, it's a 44. The rear is a coil spring rear, but not out of the same truck. GM started the 60 77 or so, Dodge in the early 70s, same with Ford. The "good" ones didn't come out till 78 on the Ford.
