yellow top optima commercial batteries
Discussion in 'The Garage' started by wraenking, May 9, 2006.
  1. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
  2. onlychevy6
    onlychevy6 1/2 ton status
    Mar 29, 2003
    1,293
    Hockley, Texas
    i use the yellow optima battery they are great. no modification was needed for me. just used the factory clamp. in the factory location.
  3. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    you have the commercial one? its a bit longer. and has no where to clamp down at the bottom.
  4. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    you'll need to change to a top clamping style.. you need to use a clamp that goes on top of the battery and then the bolts are J hooks that hook on the side of the battery tray as there tighten down
    I found this one at http://www.wranglernw.com/commerce/ItemDetail.asp?ItemNo=34%2D942
    I wish I had a friend that could get me a couple of them....
  5. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    I run that group 31 yellow top. It is longer and taller! In my 91, the factory battery tray would not work. The posts hit the hood. I took a piece of 1/8 plate and welded it to the inner fender. I also welded a 8" piece of 3/4 angle iron to the bottom for support that rests on the inner panel. You will love that battery. I would recommend it to anyone.
  6. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    can he get me two also for little $$? :)
  7. 79Jimmy
    79Jimmy 1/2 ton status
    May 10, 2000
    214
    Richmond BC, Canada
    I run a group 31 also, however I've got a '79. Great battery, lots of reserve!!! The tray mod was easy... just notched the vertical support next to the rad to let the end cell hang off the edge. Took about 2 minutes with the grinder and some epoxy paint. The hood is close but cleared fine.
    James
  8. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    I got a D31. It's sweet. IIRC, i think there was a guy on ebay who made billet trays for the D31. They were pricy though, like over $100.
    I made my own tray & hold down, i had to anyway because of the tilt front clip the battery needed re-located.
