yes, yes......more about gearing
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 85k5blzr, Mar 31, 2001.
  1. 85k5blzr
    85k5blzr 1/2 ton status
    Jan 10, 2001
    103
    Houston, Texas
    Ok, i must be losing my mind. From what i hear/read, you can tell the gear ratio by jacking the rear end. turning the wheel a few times, counting the times the driveshaft makes a full turn, and doing the math. When i jacked my 85 and turned the wheel 2 times, the driveshaft only turned 3 and so on. The driveshaft was turning 1.5 times for each wheel revolution, what am i doing wrong?
    85 k5 blazer with an old 305....must have more power! [​IMG]
  2. timebomb1602
    timebomb1602 1/2 ton status
    Mar 30, 2001
    138
    hudsonville, MI
    what size tires??????
    1991 GMC Jimmy, 350 tbi, stock for now, but not for long!!!
  3. 85k5blzr
    Jan 10, 2001
    103
    Houston, Texas
    i'm running 32"s, but a revolution should be a revolution
  4. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    I think that means you have 3.07 gears. You must turn the tire twice as you thought because of the differential.
    <font color=blue>//////
    <A target="_blank" HREF=http://blazer79.coloradok5.com>http://blazer79.coloradok5.com</A>
    </font color=blue>[​IMG]
  5. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Thats just kind of an inaccurate way to do it. Depending on what kind of diff it has sometimes it works, sometimes not. Why don't you just take the diff cover off and count the teeth? Its easy to do, its accurate and more than likely the gear lube in your axle needs changing anyways.
    '73 K5
    Chevy good...Ford bad
  6. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    If you have an open diff. make sure the other tire isn't turning. If you have a locking diff. make sure the other tire is turning. For higher accuracy, go through more revolutions, like 10 so the math is still easy.
  7. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    If you only turn one tire, then you have to multiply the revolutions of the driveshaft by 2.
  8. Emmettology 101
    May 9, 2000
    8,126
    FL
    Ya, to be more accurate, I would pull the diff cover and see what is stamped on the ring gear.
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
    "He who uses a winch...... Is tired of yankin!"
