yet another 350 swap ?
Discussion in '1983-2005 S-Series models' started by bryguy00b, Dec 27, 2003.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ok so when you do the 350 swap..what are your choices of trannys? 400,700 or 350? and what if the truck was a standerd befor??
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    any trans you want.. if it was manual before, weld up a cover on the floor and get an auto column or use a floor shifter..
  3. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    yea floor shifter is what id probobly use..what about trany mounts and all that?
  4. Confedneck
    Nov 1, 2002
    5,236
    probably end up using the crossmember from the truck that donated the trans if you can get it, if not, buy the mount for the trans and fab up a crossmember from that..
  5. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    yea...ill look around, find someone thats done the swap and see exactly what they did..
  6. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you can use the stock crossmember in the stocl position you just have to make the hole in the crossmember longer /forums/images/graemlins/thumb.gif
  7. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    really..cool! ive been thinking about hanging on to the 305/700 combo from my blazer...although i dunno if that would work with a 4wd tranny??..
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    tranny has to be 4x4 output tail shaft deisgn, that goes for all tranny models, th350 woulds be easiest and pretty much most reliable and least costly.
    700r4 mount is in different place than 350 i know, but not than 200c, btu no 200c are 4x4 output from factory.
    good luck
  9. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    why does it have ot be a 4x4?
  10. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Probably because he thinks your S10 is a 4x4 rather than 2wd... Since you have a manual 4 spd now, your best option will probably be a T5, 5 spd out of an 86-94 S10 (found with 4 cyl and 2.8 V6 models) or an NV3500 found behind the 4.3L V6 (the nv3500 being the simpliest swap). For a stock 305 or 350 either tranny would hold up with the light weight and mild use in a 2wd S10. However, if you drive it like you stole it neither one will last forever.
  11. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    with a v8 in a s-10 ur damn right i would drive it liek i stole it! /forums/images/graemlins/wink.gif /forums/images/graemlins/deal.gif /forums/images/graemlins/thumb.gif
  12. kennyw
    Jun 9, 2002
    13,224
    94
    Then dont worry about what tranny will last because none of them will /forums/images/graemlins/wink.gif /forums/images/graemlins/rotfl.gif Just find what is easiest/cheap to put in and get spares /forums/images/graemlins/thumb.gif
  13. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    haha /forums/images/graemlins/rotfl.gif
  14. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I would go with a stout 700R4 in a truck that light. The lower first gear helps it launch as if it had much lower gears in the rear end, while the overdrive is nice for keeping the revs down on long highway trips. /forums/images/graemlins/thumb.gif
  15. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    oh its gatta be a standerd.. /forums/images/graemlins/grin.gif
  16. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    I break WAY too many parts when I drive a stick. I think it has something to do with not lifting my right foot as I slam the speed shifts at every opportunity! /forums/images/graemlins/eek.gif /forums/images/graemlins/thumb.gif
  17. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ok, to save opening up another post..i have another question. my s10 is TBI 2.5, so if i put a carbed 305 in there, what would i do about the gauges ect. there all dumby lights..but would i have to put in a bunch of aftermarket gauges and just call it good? bypass the computerized ones?
  18. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The wires for idiot lights go directly to the dash...the computer doesn't care about the idiot lights (except the check engine light)...but if you are putting in a V8 I would want to know how it is doing so I would either swap in another stock gage set with all the gages or do it all aftermarket.
  19. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    i was thinking of just buyingg all seperate oil,temp,volts, rpm, and maybe take the tank out cause it would have to be a mechanical pump, maybe just throw a fuel cell in the back...this wouldnt happened for a while, i still need to rebiuld the engine yet..but just thinkin ahead..
  20. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    im gonna start on mine next week, need to change the cam (motor is not going in my k10 any more) and find a tranny to rebuild and i can through it together /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif
