Yet another 57" spring swap poll
Discussion in 'The Garage' started by big pappa b, Jun 14, 2004.
  1. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Yet another 57\" spring swap poll
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Re: Yet another 57\" spring swap poll
    and turn them around 1st. mine used a 9/16 and a 5/8" bolt so after mounting mine the normal way and then trying to turn them around I would of had to weld washers on the front mount to shrink the hole. plus cut too much of the body off (willy's body)
  3. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I'm flipping my 56's around for 3" plus the flip should be about 2" back for me... /forums/images/graemlins/thinking.gif
  4. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    I have mine with 1" less wheelbase right now but will be flipping them around. Don't know if I have enough driveshaft to accomodate the extra length though
  5. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Mine are in backwards and I think I gained about 6" of wheelbase.
  6. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Did you have to change driveshafts?? with 6 extra inches of wheelbase??
  7. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    I installed mine in the original direction. I redrilled the pack 1 3/4" to correct and gain wheel base. Then made zero rate type blocks to gain another 1 1/2". /forums/images/graemlins/truck.gif
  8. fwdjunky
    fwdjunky 1/2 ton status
    Oct 12, 2003
    499
    Maricopa, AZ
    I'd go long side forward to save the departure angle, but that's just me. I'm at 118" already, planning on putting 52's in the front and reversed 56's in the rear then cutting about 10" out of the frame to get back to 115" total....you know, when the D60, onboard air, sliders, cage, tires, half doors, removable cab, NV4500, doubler, and cutting brakes are in....then I'll get to the springs and frame... I need to quit my job.
  9. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Yes, w/ the added wheel base I made a new driveline out of a 1ton shaft.
