yet another ? about my broked t-case
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sammyt, Jan 30, 2003.
  1. sammyt
    sammyt Registered Member
    Jan 19, 2003
    10
    Texas
    is there a trick to getting the front shaft( the one for the front wheel drive) in the t-case to slide into the pit on the back half of the casing? np 241c
  2. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    that shaft slides inside a bearing in the case, the bearing has to be pressed into the hole in the case, the shaft should slide freely into the bearing, which part won't fit?
