Yet another D60 question. Help me Mr. Wizard.....
Discussion in 'The Garage' started by Desert Rat, May 11, 2004.
  1. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Ok, got to bolt up the D60 today. I have a stack of u-bolts so I wade through them and find the right ones. I get the driver side on no problem. I go to do the passenger side and run into some issues. First of all, I'm not sure I have the right top plate. There are a series of numbers on it, 326428, and it is the only one I had left over. My D60 wasn't assembled when I got it so I'm assuming it is the right one.
    When I go to put it on, I can line up the outboard holes with the u-bolt. However, the plate sits too far out to line up the inner holes to the axle holes for the bolts. And, when it sits on the axle, in order to make the holes reasonably line up, the bolt hole for the sway bar is facing the differential, not outwards as it should ( I think ). You can see that the inboard holes are closer together and the outboard holes farther apart precluding turning it around. Here is a pic of the plate and the u-bolt:
    Did I get the wrong plate somewhere? There is a gap also between the spring and the axle. I'm wondering if this is a factor as well. Pic here:
    Any help would be appreciated /forums/images/graemlins/dunno.gif
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    it goes on only 1 way
    I would start by putting studs in the housing and then see where you end up
    bolts = bad
    you will end up either breaking the bolt in the housing or ripping the threads out of the housing
    neither sound like a good time
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Check out the pics on this page... Swaybar mounts 'outboard' on the pass. side.
    http://www.coloradok5.com/swaybardisconnect.shtml
    Many aftermarket springs seem to be a bit narrower than the stockers. Not sure if it matters /forums/images/graemlins/dunno.gif
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    hmm
    mine has 370056 cast into it
  5. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    If that is the right spring plate, it only mounts one direction. The narrow holes go towards the differential with the hole for the swaybar towards the passanger side. The gap between the spring plate and the differential is not a problem.
  6. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    That's what's funky. My spring plate has the narrow holes on the side that the swaybar mounts in as you can see in the pic. And, the holes for the inside mount seem to be just a little off. The wide side is for the u-bolts. I'm thinking I have the wrong spring plate which ticks me off since I POR-15'ed it already. /forums/images/graemlins/angryfire.gif
  7. u2slow
    May 9, 2001
    2,217
    BC Canada
    Hmmm... Probably a D44/Corp10 plate. On these, the wider u-bolt is on the pumpkin side. /forums/images/graemlins/thinking.gif
    Maybe you don't need a swaybar /forums/images/graemlins/grin.gif
    (I ditched mine.)
  8. marine_enlisted
    marine_enlisted 1/2 ton status
    Sep 29, 2002
    658
    Stafford, VA
    I bet you have a Ford or Dodge springplate.
  9. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Does the dealer even carry these anymmore? Other than scrounging a wrecking yard, I'm wondering if LMC has one.
  10. marine_enlisted
    Sep 29, 2002
    658
    Stafford, VA
    They are $45 a piece from GM Parts Direct here are the part #'s passenger side(pumpkin side) # 370056 drivers side # 370055
    A 10 bolt or D44 plate will work on the drivers side if you don't mind squeezing the u-bolt just a little to get it into the holes. I only have a pumpkin side D60 plate and I plan on using the 10 bolt plate on the drivers side.
  11. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Perfect! Thanks, ordered one up today. /forums/images/graemlins/waytogo.gif I wish they had options on shipping from GM Parts Direct though. I would've rushed it.
