Yet another hydro assist question
Discussion in 'The Garage' started by 1976Blazer76, Aug 18, 2006.
  1. 1976Blazer76
    1976Blazer76 1/2 ton status
    Apr 17, 2006
    552
    Ridgefield, WA
    I've been searching and I've yet to come up with the answer I'm looking for. When setting up my hydro assist, do I want the ram to stop before it hits my mechanical stops. That sounds like the way to go because the hyraulic will push through my mechanical stops correct? Yet, I don't want to stop before my mechanical stops do I? Because that will make all the pressure at full steer to be on my hydraulic.
  2. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    The ram will be your stops. You can take the factory ones off the axle.
  3. 1976Blazer76
    Apr 17, 2006
    552
    Ridgefield, WA
    Thats what I was thinking, thanks.
  4. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    Using the ram to limit your steering travel is just like using shocks to limit your suspension travel. Lots of people do it, and there are some that break shocks/rams because they do it. The correct way is to have the ram and the steering stops on the knuckle bottom out at the same time.
  5. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    A hydro ram is nothing even close to a shock. Hmm, when I bought my hydro set up back in 2003 the instructions even said the ram is now going to be the steering stop.
  6. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Set it up where they stop at the same point.
