Yet another shackle flip ?
Discussion in 'The Garage' started by sandawgk5, Dec 13, 2005.
  1. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I am going 56s but I do not know when they will get here and I do not want to move the flip brackets 1 week after I install them sooooo.
    What are some possible problems with putting the flip in the 56" spring position and leaving the 52" springs in until the new springs arrive. This is not a DD and it is up to Roz but I prolly could leave it in his driveway if it is physically impossible to drive or unsafe. I would only be going maybe 3 miles to my house and then back to Roz's when the springs came.
    Ira
  2. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    my guess is the flip would be far enough back that the shackle would move past vertical... not good. Just wait until you have the 56s.
    j
  3. sandawgk5
    Oct 28, 2003
    6,881
    That is what I was thinking. I will prolly have to have the GHAY California lift for a day or two. Atleast we will be able to move it around the yard.
    Ira
  4. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    well just leave it. we will move ure blazers sister over and there will be enough room.
  5. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Sounds like you should've gone with the sky kit.
  6. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    my setup is 56's, flip in the 52's spot on the CORRECT side and extended shackles. (the drop shackles flipped over) the shackle angle is perfect, and the shackle gives tons of droop. theres more pics in my gallery, the thing will flex alot more but i dont have enough weight the rear end to keep the tires down and dont have extended shocks yet.
  7. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I believe he was asking a question about runnin them the opposite way though. Your brackets are set for 52's and you run 56's which is why your shackle is like it is. He was asking what problems could arise from putting the brackets in the 56 position and running the 52's whick would move the shackle the other way more like | which could cause some issues.
  8. sandawgk5
    Oct 28, 2003
    6,881
    That is exactlly what I was asking about and have decided to stay safe and just leave it alone until the rear springs get here.
    Ira
