Yikes! Why you need to upgrade your shackles....(pics)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by morphed86k10, Oct 14, 2002.
  1. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    Had a great day of hard wheelin yesterday (Sunday) but my steering felt a little loose afterwards...I think this could be the problem:
    Shackle carnage 1
    Shackle carnage 2
    So once again I'm patronizing ORD /forums/images/graemlins/wink.gif
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    yup, i swapped mine out a few weekends ago, after harassing one mod here for his suggestion over the fone (thanks greg! /forums/images/graemlins/cool.gif )
    Mine was cracked, didn't know it. Now my axle is move a bit forward a bit more and with the x-over, steering is great...
    now i just need to make time for the AGR powersteering pump /forums/images/graemlins/crazy.gif
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Ouch! /forums/images/graemlins/eek.gif
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Had the same thing happen to the Brown Turd K30 once. Just slapped on another spare shackle I had laying around. /forums/images/graemlins/wink.gif
  5. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    WOW! /forums/images/graemlins/eek.gif That looks like it was fun to drive home that way! I think I am gonna get my shackles soon!
    Bill
  6. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    wow now i feel pretty good about buying those hill4wd shackles.
  7. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    And don't forget to upgrade those shackle bolts also!! I just broke my 3rd 1/2" grade 8 shackle bolt!!! This was with NO wheeling!! What do you guys think about running a 5/8" bolt directly against the poly bushings (presently it has a 1/2" bolt with the steel tube spacer, that allows the bushing to be shielded from the bolt). Other than that, I'm thinking of obtaining some higher grade bolts, perhaps grade 16?? A friend told me they use that grade on Caterpillar dozer blades... /forums/images/graemlins/shocked.gif
  8. BigMac
    BigMac 1/2 ton status
    May 27, 2002
    397
    Fremont, CA
    Dude, consider yourself lucky... I have some frame repairs to do because of something like that...
  9. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I have done this, the only thing you have to do is get lock nuts and don't overtighten the bolt just get snug.
    Never broke a bolt after that.
  10. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,072
    484
    Grand Rapids area
    I made my own out of some steel that is at least twice as thick as the stock shackles. They have 3 top holes so that I can adjust the front ride height in 3/4" increments. I use them with the ORD greasable bushings.
  11. efilnikufecin
    efilnikufecin 1/2 ton status
    Feb 27, 2002
    168
    flint,mi
    i used 5/8 in mine along with some 3/8X 1 1/2 cold rolled flat stock.never had any trouble.
  12. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    The problem with this is that trying to lift your truck with longer front shackles really screws up the pinion angle. Not only that, but you can also make the truck a hand full on the road by screwing up the Ackerman(sp?) angle. It can become very twichy which isn't fun in a top heavy truck! /forums/images/graemlins/eek.gif
    Mike
  13. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Ackerman isn't affected by shackles, it's the caster that's affected. Going a little buit longer is generally OK, but more than a couple inches I'd start getting a bit scared. However if you have the axle shimmed to aim the pinion up towards the t-case, the longer shackles will actually put the pinion closer to stock than it would be without them. /forums/images/graemlins/wink.gif</font color>
  14. CooknwithGas
    CooknwithGas 1/2 ton status
    Nov 27, 2001
    332
    Istanbul, Turkey
    Another clue that your shackles may need replacement is if your truck leans to one side. It gave me fits adjusting the body mounts trying to level the truck before I found a worn out shackle bushing. The spring was resting against the frame.
  15. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    I know not to over-tighten the bolts. Had lock nuts on there also. 5/8" seems to be the way to go. I still can't beleive that stock GM uses 7/16" shackle bolts!!!
  16. Blue85
    Jul 26, 2000
    9,072
    484
    Grand Rapids area
    This must be why I have had zero problems with it! Others have had similar results. It's even possible that this change could make it handle better. Changing the front height by 3/4" (1.5" longer shackle) only affects caster by about 2 degrees. If the caster is right on in your "average" height, you can go up or down a little bit and still be acceptable. You just don't want to have marginal caster to begin with and then put 2" longer shackles in. In that case, you will need shims.
    It takes a lot more than shackles to change the Ackerman angle.
